Waterspots -Can't get rid of em
#41
I used Meg's compound on my son's 14-year-old Nissan. It was amazing. It had years of pollen stains, bird droppings and water marks. This car looked as bad as you could possibly imagine.
Modern compounds are a lot different from the old days. Not nearly the gritty stuff we had when we were kids.
Anyway, I used it sparingly and did one panel at a time. The car was like new about an hour later. Didn't take long at all. You wipe it off before it has time to dry.
I then applied a sealant - NXT - and the car looks like new.
This stuff took everything off with no damage to clear coat. It was funny. I went to fill the car up afterward and put the gas cap on the trunk and it promptly slid right off.
#42
Another post mentioned Barkeepers Friend, it will work, though I have concerns about it being near the paint.
Vinegar will sometimes work, if you take long enough to let it soak.
Another post mentioned using glass polish, this will work but is way overkill, that much abrasion is not necessary for water spots.
I detail cars on the side and want to use something safe, effective and fast. I use the paint polishes to remove water spots from the glass, it takes a minute to clean up each window.
Here is a little write up example (though not on a vette)
This vehicle was in pretty bad shape. It regularly was getting sprayed by hard water from an irrigation system and then baked in the hot Florida sun... for the past 3 or 4 years!!
This is how the glass looked after: pressure wash, two bucket wash, clay, glass cleaner ... and still left heavy spots everywhere and still looked like crap!
After using Adam's green 4" focus pad (can be used on a drill or a PC7424) along with the Adam's Severe Swirl and Haze Remover it looked clean. Then for an amazing gloss I switch from the green pad (made for the Severe Swirl and Haze Remover) to the white 4" focus pad with a couple drops of Fine Machine Polish and a couple drops of Revive Polish. (this really is a white pad, just picking up the black material from doing a couple windows)
The results are remarkable! And most importantly the owner is thrilled too!
This picture is focused on the glass like the first picture was... but no spots visible! Had to use manual focus as the camera couldn't see the glass anymore!
These next two pictures show how mirror clear the reflection is now.
This can be done without the machine by using the hand applicators, the machine just makes it faster.
#43
FYI for the Glass .. I have not tried it but find their other products to be very good ...
http://www.mothers.com/02_products/06712.html
#44
I had a similar problem using Zaino; some water spots that I didn't see got trapped in the lower part of the nose. I tried vinegar and it did not work, I think I also tried alcohol. I contacted Zaino they suggested vinegar or Z-AIO. Z-AIO (zaino all in one) it's amazing, it got rid off them, it took just a little bit of elbow grease but they came out. If you trapped the water spots under wax, you are gonna have to deal with the wax first; dawn detergent may strip some of that cheapy turtle wax. Z-AIO can be used also as a foundation for Zaino if you wanna try something better than turtle wax
Zaino also has stuff for the glass, I haven't tried it yet but I assume it may be pretty good as well.
Good luck!
Good luck!
#45
Help!
I made the mistake of washing my car in the sun...
I used Turtle Wax Car Wash solution.
Now I've water spots all over the car including the glass.
Just working the glass, I've tried Windex, Invisible Glass, Simple green, dishwasher solution in hot water, even car wax -nothing made a difference.
Anyone have any thoughts on getting rid of the spots
Let me know if you found anything in the way of a remedy. Good Luck....a
#46
I see the date on your post. Did you find an answer to the water spots? I have them on both cars and I've use everything. Especially on the glass. I think Simple Green Wash and Wax did it. I've tried CLR, Phosphoric Acid, Vinegar, Steel Wool, Buffing Machine, Razor Blade. All to no avail. Only thing that seems to help is waxing the glass and the body w/ good past wax.
#47
#48
First try XXXXX steel wool it will not scratch your glass and 85% of the time removes really bad waterspotting on the windows.
The absolute best stuff on the market is Zaino Z12 Clear View.
I live in Reno and the water and the lack of humidity instantly make terrible water spots especially if you use a washing soap.
A friend had tried everything from steel wool to rubbing compound and it just wasn't coming off. I brought him my bottle of Zaino and within 10 minutes his Denali was perfect.
#49
Old thread revival for sure. But my $0.02, not all water spots are made equal. Sometimes vinegar works, but not for really hard or water with lots of sediment. Maybe you can soak it for a while with a towel and get them lightened, but sometimes that just won't cut it. Clay bar generally works ok, depending on how aggressive the clay is and how much elbow grease you use. If you wanted to try something cheap and over the counter, I would go find a decent clear wax. It will likely have just enough abrasive for you to work out the spots individually. I've used #6 Meg's many times with great success for water spots.
#51
I had the same problem on my glass. Find a real fine steel wool. This will take off the water spots and will not hurt the glass. On the paint had to buff the water spots out.
#52
Clay
I even used it with spraying Chadwicks detailer and it gave me a good result.
JB
