Car died.
Old May 21, 2012 | 05:28 AM
ppwcclub's Avatar
ppwcclub
Default Car died.
Friday I took our 2005 vette out for a drive after about 20 minutes on the road all of the gauges went to 0 and all the warnings went off say low fuel, low tire pressure, low everything. I was about 5 minutes from the local Chevy dealer so I drove it to there and when I shut the engine down it wouldn't start again. They try to jump it off and that wouldn't work, they hook the computor to it and it gave them voltage errors. He check the alternator which was changed about 8,000 miles back and said it was good. While sitting there tring to find the problem the seat started to move and the green light came back on the start button and then it would crank, hook it back to the computor and no voltage problems. Any idea of the problem, would hate for this to happen on a trip far away from a chevy dealer. Thanks
Old May 21, 2012 | 06:41 AM
truckplay's Avatar
truckplay
Default start backtracking
if the last thing you did was swap the alternator check your cables and ends at the alternator and battery, something came loose.
good luck
Tom
Old May 21, 2012 | 08:02 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Shorted battery. Sulfate in the bottom accumulates from abuse. It finally shorts between plates or the plates warp and touch each other. Battery acts like a short. The power flowing through this short can burn the sulfate away and the battery returns to normal operation.
BTW, it's computEr. Periods are your friend. Grammar isn't just for students any more.
Old May 21, 2012 | 08:26 AM
VetteTico's Avatar
VetteTico
I had these same things happen to me while traveling on Easter this year. It seemed like the problem was related to the hot outside temperature. Luckily, the car started for the return trip home and I was able to take it into the shop the next day.
The vette dealership near me corrected the problem by reconnecting something in the body control module (if this is not at the top of the passenger footwell they had to reconnect something in that area too), something in the steering wheel was off track (solenoid maybe?), and they reprogrammed my computer and key fob.
So far no problems 6 weeks later. Hope this helps, I know it's not real descriptive but I was just happy to have my car back/fixed.
Old May 21, 2012 | 08:37 AM
TLS_Addict's Avatar
TLS_Addict
An older guy warned me of this EXACT thing Friday night when his Vette was parked next to mine at the mall. He has an 07 and he told me to watch my battery. lol
Also, go around correcting grammar and guys get mad at you around here. Just sayin'.
Old May 21, 2012 | 09:06 AM
ppwcclub's Avatar
ppwcclub
The battery was new 5/2010. We drove it another 30 or 40 miles this weekend with no problem. I think I will replace the battery to be on the safe side and all the connection on the alternator are tight, first thing we checked. Thanks
Old May 21, 2012 | 09:35 AM
bearphoto's Avatar
bearphoto
SoCal Events Coordinator
St. Jude Donor '12
Definitely sounds like a battery problem. When they are in the process of dying you will get all kinds of crazy electrical issues.
Old May 21, 2012 | 02:09 PM
Dendk's Avatar
Dendk
Yea it sounds battery related, they only last around 2 years out here (excessive heat).
Old May 21, 2012 | 02:16 PM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
Why? how old is your grammer?
Old May 21, 2012 | 11:11 PM
Gary '09 C6's Avatar
Gary '09 C6
also make sure the battery cable connections at the battery, and at the starter and ground, are tight...
Old May 21, 2012 | 11:38 PM
johnodrake's Avatar
johnodrake
Moderator
Before you spring for a new battery, check all the grounds - there are like 12 of them.
http://forums.corvetteforum.com/1564664336-post7.html
Old May 22, 2012 | 07:39 AM
FortMorganAl
How many times has this battery been discharged? If never or less than twice then I will revise my comment. A battery should be able to last more than 2 years even if abused a few times. It might be a bad connection. Alternator connections were checked so I will assume the battery connections were also checked. That leaves the negative connection to the engine block as the next most likely to cause the issue as described. Temperature cycling might have caused this connection to break and then make again.
Old May 22, 2012 | 08:35 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You might should jack up the right front and get under there to the starter solenoid and check to insure the battery connection there is clean and tight. Do not forget that its electrically hot there.
To Car died.
