scraping front end
Old May 28, 2012 | 12:48 PM
pgwaterman's Avatar
pgwaterman
Default scraping front end
just bought a new grand sport unfortunatley backing it into the garage last night it scrapes in the front, besides tearing my driveway out are there any kind of ramp products out there that anybody knows about to lift the front end up about 2" for clearance .
thanks for any input you might have
pg waterman
Old May 28, 2012 | 01:07 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
pg waterman
Could you consider simply driving the car in to the garage? This would keep the nose on the incline both in and out and you have more clearance in the rear.
Old May 28, 2012 | 01:13 PM
SanDiegoBert's Avatar
SanDiegoBert
If it's just the rubber airdam scraping, that's not something to worry about.
Old May 28, 2012 | 02:39 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
The 'sacrificial' air dam under the car costs $100 total, to replace all 3 sections.
Don't worry about it, and you will undoubtedly be scraping other inclines/ramps/etc. too.
Old May 28, 2012 | 02:45 PM
GSRANDY's Avatar
GSRANDY
Try driving in and out of your driveway approach very slowly at a 45 degree angle, should help the situation.
Regards,
GSRANDY
Old May 28, 2012 | 02:54 PM
LS WON's Avatar
LS WON
Put more air in your tires.
Old May 28, 2012 | 03:40 PM
Herrick's Avatar
Herrick
I replace mine once a year. It helps if you go up and down inclines at an angle. As previously said, all 3 parts cost about $100.00. I get mine from GM Parts House. It takes about 20 minutes to do it yourself.
Old May 28, 2012 | 03:52 PM
CMCvette's Avatar
CMCvette
Used to have this problem as well- driving in at a 45 degree angle helped. Hopefully it is just the black plastic that's dragging, which as others have noted, is not big deal (just sounds awful!).
Old May 28, 2012 | 03:57 PM
LS WON's Avatar
LS WON
It's normal for it to scratch and it does on every driveway anyway. As I inspect underneath car I can see scratches elsewhere on the frame and don't know where those came from. It goes along with owning a car that is low. Next time I'll get a muscle car with higher clearance.
Old May 28, 2012 | 06:49 PM
ChevyDave's Avatar
ChevyDave
there are adjustment bolts, if you think you only need 1/2" to 1 ", you can have then turned clockwise to raise car. 4 turns will get you just over 3/4". there is a description and pic somewhere on here for doing it, forget where i found it.
Old May 28, 2012 | 08:54 PM
LS WON's Avatar
LS WON
Old May 28, 2012 | 09:00 PM
JCtx's Avatar
JCtx
Folks, the 3-part 'spoiler' does not hit on inclines; it's the more expensive chin spoiler. DO NOT back into an incline on a low car . Best way to avoid contact is entering at an angle, as previously suggested by some. If it hits like that, then you're screwed. You can always put different leveling materials, like some do, but at least my wife wouldn't approve of them . I've always avoided houses with inclined driveways, but once you live in one, cannot fix it until the next . Good luck.
Old May 28, 2012 | 09:12 PM
Mad*Max's Avatar
Mad*Max
I've been scraping mine for over 5 years, no worries, just take it easy where it scrapes.
Old May 29, 2012 | 12:36 AM
TKgs2010's Avatar
TKgs2010
pg waterman
Join the club, my friend! Same thing with my GS, the scraping you have is just the lower air dam under the radiator, and it's pretty much a wear item. The part is in 3 pieces and costs about $100. That being said, my driveway is fairly steep, and there's really nothing I can put in the concrete drain area where my driveway meets the street, so mine always scrapes just slightly, and that's going out at a pretty good angle. Really, nothing to worry about.
Old May 29, 2012 | 01:16 AM
CO Lightfoot's Avatar
CO Lightfoot
...are there any kind of ramp products out there that anybody knows about to lift the front end up about 2" for clearance...
Hard to say for sure. A picture of your driveway would help.
Something like this might work for you:
http://www.bridjit.com/
Or, maybe a metal plate or simple piece of wood might do the trick.
Old May 29, 2012 | 05:25 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
It sounds like more than the air dam if its tearing up his driveway?
Old May 29, 2012 | 08:41 AM
heli-vette's Avatar
heli-vette
I agree with cranking up the suspension height and cut an inch off the air dam with snips .
At times you can't slow down to enter a driveway in traffic , end up bouncing the frame brackets off the cement .
http://forums.corvetteforum.com/c6-t...front-end.html
To scraping front end
Old May 29, 2012 | 12:09 PM
Vivid1's Avatar
Vivid1
I've been scraping mine for 2 years. The air deflector is fine.
Old May 29, 2012 | 01:12 PM
SanDiegoBert
At times you can't slow down to enter a driveway in traffic , end up bouncing the frame brackets off the cement .http://forums.corvetteforum.com/c6-t...front-end.html
Man, I hate it when the radiator supports hit the pavement. Happens more than I would like, and my car is not lowered.
However, when the air dam scrapes, it just another one of those endearing C6 sounds . . .
Old May 29, 2012 | 01:13 PM
Raazor's Avatar
Raazor
Goon Squad King of Battle
St. Jude 15 Year Donor
St. Jude Donor '08 thru '23
this yo
