Sway bar bolt cross threaded
Old May 30, 2012 | 12:38 PM
EVL JAKE's Avatar
EVL JAKE
St. Jude Donor '12-'13
Default Sway bar bolt cross threaded
So I swapped out my mufflers yesterday and I noticed one of the top sway bar bolts came out very easy and the other was hard. Same when I put it all back together. After doing some research it seems like whoever worked on the exhaust before me cross threaded one of the bolts since is a common issue. Any way to fix this? Can a chase the thread and buy a new bolt or is more needed? Should I just live with it. I will be swapping the muffler again and probably upgrading the sway bar so i don't want a bigger issue.
Old May 31, 2012 | 04:01 PM
EVL JAKE's Avatar
EVL JAKE
Anyone?
Old May 31, 2012 | 04:05 PM
johnodrake's Avatar
johnodrake
Moderator
Originally Posted by EVL JAKE
Anyone?
I would try a thread chaser and a new bold. If that doesn't work, a helicoil may or you may be able to drill the mount and rethread for a slightly larger bolt. I would hate to think of replacing the rear carrier! Yikes!
Old May 31, 2012 | 04:29 PM
Dif's Avatar
Dif
1st, .. it's worth a shot to see how good the thread is, after chasing it with a Tap.
It may work good, ... and the only way to know is if/when it gets Torqued and does not strip out further.
On the other hand,.. IMO, .. chances are the threaded hole in the carrier is already compromised
Do it right and put a Helicoil in!
It will take some patience and skill but will be fixed correctly with a Helicoil and no future fear of it being a problem.
Good luck and hope it works out OK
Old May 31, 2012 | 05:28 PM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
I repaired a bad bolt hole in an aluminum alternator with a helicoil about 15 years ago, on my truck, and it has worked perfectly for a number of belt changes and belt adjustments ever since. And, it is NOT that hard to do. Go for it.
Old Jun 1, 2012 | 08:52 AM
EVL JAKE's Avatar
EVL JAKE
Thanks guys. For the moment it's holding at torque so I will looking into a helicoil once I take it off again.
To Sway bar bolt cross threaded
