Battery Tender Question
Old May 30, 2012 | 08:24 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Originally Posted by cegusa
FWIW, I did have a CTEK fail. Not saying it's an inferior product but it did happen. What I wound up doing is reverting back to a Battery tender plus and got one of their longer extension cords. I was able to snake it through the gills on my GS and tuck in with a Velcro strip when not in use. It was really easy to do. Clipped of one plug, installed a couple of high quality eyelets and an the hot to the spot next to the fuse box and ground to a spot on the frame. I did the lighter adapter thing with the CTEK for a while before it failed but really didn't like running the cord out the door. CTEK also doesn't have the longer cord ( or at least I couldn't find one) so I couldn't run that one through the gills as I hoped I would have been able to.
pretty sure both batt. tender and ctek stand behind their products; shouldn't fail and they'll replace if it does.
as to OP's q. and others, my schumacher fr. advance auto was pretty inexpensive. after about 5 years it did fail. no freebie.
the ctek 3300 is all you need. just note to use it, a lot, even when you leave the car a few days. can't hurt. get the one from one of the vendors that includes the car cig lighter connection and run it over the top of the window vs. under the door (door, even with "dimple" does crimp wire). and remember each time you disconnect it from the hot outlet (cig or console), you have to plug it in AND reset it to car charge by pushing the buttons. if you don't do that, it's connected but it's not doing a thing.
Old May 30, 2012 | 08:29 PM
LS WON's Avatar
LS WON
Originally Posted by capevettes
That may be it. All I can say is that I've been at this Corvette thing for 41 years and tried almost everything, including MANY different battery tenders. Many have failed, over charged, went into float mode when the battery needed charging etc. This one works flawlessly. I haven't tried the Schumacher but I have no plans to change at this point.
You have the CTEK 3300?
Old May 30, 2012 | 08:39 PM
Nice Ride's Avatar
Nice Ride
Good info on battery tenders on the forum if you do a search. I use a Deltran Battery Tender Jr. which works fine but they make a Plus which may be better. Other brands are popular as well like CTEK. I connected to the negative and positive terminals of the battery. There is a small bold that holds the cable tight to the post. I removed the bolt being careful not move the cable connection and put the O-ring connection over the screw then replaced the head bolt. I tied up excess wire from the tender connection from the battery so I could keep it neatly secured by the battery area when not in use. There is a plug on the other end of the cable you attached to the battery that mates the plug that comes from the battery tender. Once joined then plug the tender into a wall plug directly or via extension cord. Just follow manufactures directions and you are good to go. I do not close the hood but rather allow the hood to rest on the stops which leaves a small gap which I run the wire from out over the fender. That is what I do and there may be a better safer way so check it out. Some guys ground the tender to the motor and some use an adapter to the lighter in the car and run wires under the door. Whatever system/method you use a tender will solve the dead battery problem.
Old May 30, 2012 | 08:44 PM
Mad*Max's Avatar
Mad*Max
Originally Posted by sar10
I use my 3300 with the cigarette lighter adapter and run the cord under the door using the cutout notch in the sill plate. Works for me.
Old May 30, 2012 | 11:31 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
To guard against forgeting the CTEK and driving away with it still plugged in (yes, people do that and I have no wish to imitate them); I use the cig lighter plug and bring the wire in under the driver door, so it drapes across my seat.
Pretty hard to miss seeing it.
Old May 30, 2012 | 11:39 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Old May 30, 2012 | 11:56 PM
SpryGeezer's Avatar
SpryGeezer
http://www.amazon.com/CTEK-Multi-700...8436423&sr=8-1
If you enjoy a dozen battery diagnosis status lights as I do.
Old May 31, 2012 | 12:14 AM
LS WON's Avatar
LS WON
They do? and have?
Old May 31, 2012 | 12:16 AM
LS WON's Avatar
LS WON
http://www.amazon.com/s/ref=nb_sb_no...attery+charger
The 7002?
Old May 31, 2012 | 12:19 AM
LS WON's Avatar
LS WON
Originally Posted by CO Lightfoot
For a weekend car, definitely use a good battery maintainer.
You can connect directly to the battery. That's what I did when I first got my CTEK. Then I experimented with other methods.
Bottom Line: IMO it's more convenient to use CTEK's optional outlet adapter. http://www.amazon.com/CTEK-56-263-Co...=pd_sim_auto_1
Either outlet works fine. I use the center console outlet because that's where I store the adapter.
And I leave the lid open as a reminder to disconnect it before driving away.
Just make sure you don't crimp the cord -- it should move easily when the door is closed.
Lots of threads on this topic, like this:
http://forums.corvetteforum.com/c6-c...r-hook-up.html
You mean the Cig. Plug?
CTEK 56-263 Comfort Connect Cig Plug by CTEK
Buy new : $11.99 $9.99
Old May 31, 2012 | 07:36 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Yes I actually have 5 of them. Never had an issue with any of them.
Old May 31, 2012 | 08:10 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
wHAT makes this charger so superior over the Schumacher at Wal-Mart
Is it that Desulphate phase of reconditioning battery?
Price. It's got the Corvette tax added from the factory.
Battery Tender, Schumacher, even Harbor Freight all are "computer" controlled and will desulfate the battery as well as any other. The one thing I dislike about the CTEK is that it may have to be manually reset when the power goes off while all of the others are totally automatic in going through their various modes of operation.
Old May 31, 2012 | 08:24 AM
  #33
AWARE02's Avatar
AWARE02
St. Jude Donor '15
Default Battery Tender
Check these out! I have had three of them on different cars...awesome product!
http://store.corvettemuseum.com/detail.aspx?ID=3495
Old May 31, 2012 | 05:58 PM
  #34
Gearhead Jim
St. Jude Donor '13
Our CTEK 3300 with the Corvette logo is ok with a power interruption, it picks up where it was before.
Not sure about other models of CTEK.
I thought I saw someone complaining about this problem with a Schumacher, but haven't looked up the thread.
Old May 31, 2012 | 10:04 PM
  #35
LS WON's Avatar
LS WON
So your CTEK 3300 as noted below is the opposite in that it will automatically reset when the power goes off? It doesn't need to be manually reset when the power goes off as mentioned below?
"Battery Tender, Schumacher, even Harbor Freight all are "computer" controlled and will desulfate the battery as well as any other. The one thing I dislike about the CTEK is that it may have to be manually reset when the power goes off while all of the others are totally automatic in going through their various modes of operation."
Old May 31, 2012 | 10:14 PM
  #36
funymuny's Avatar
funymuny
I bought one of each. Plus some of the other 'less expensive' tenders cuz I have too many toys with batteries. I'm impressed with the ctek's, but depending on the need and your level of care, the Schumachers from Walmart may be just fine. I have one boat, two waverunners, the GS Vette and a riding mower. And I admit I was experimenting with them a little.
Old May 31, 2012 | 10:37 PM
  #37
CaryBob's Avatar
CaryBob
Me too. Considering it's the same price as the Corvette-branded product, it's hard to pass up.
To Battery Tender Question
Old May 31, 2012 | 11:09 PM
  #38
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
I use the Battery Tender Plus (green one) on my Z.. with the Cig lighter adapter...so simple and easy to connect, and run the cord through the slit in the door sill, and you can shut the door all the way without crimping the cord. This is especially nice for Z06 (and some GS), ZR1 folks who have the battery in the rear hatch compartment.
honestly even if my battery where under the hood, I would use the cig lighter adapter too. the easiest way IMO
Old May 31, 2012 | 11:35 PM
  #39
LS WON's Avatar
LS WON
Exactly where is this location of the slit in the door sill so you can shut the door all the way without crimping the cord? Mine is a basic 2005 coupe.
Old May 31, 2012 | 11:36 PM
  #40
LS WON's Avatar
LS WON
Is this the CARTEK 7200 model?
