Help with my '07 DIC...
Three of the lights have gone out on the right side DIC buttons. Can I replace just the bulbs or does the 5 button unit/pod have to be replaced?
Anyone know what bulbs they are if thats all it is?
Thanks!
Thanks!
One of mine is out too. I think it would be a lot easier to replace the whole pod. I dont think the bulbs are meant to be replaced but I'm not saying they cant be.
Premium Supporting Vendor
Location: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
Not sure about the bulbs but the "button cluster " can be easily replaced and they are not expensive.
Received 1,116 Likes
If you can solder, they are easy to replace with these from Radio Shack: http://www.radioshack.com/product/in...ductId=2103780
When I did it, I read on the forum that when you replace one there is a chance the one next to it will blow soon so just replace them all.
These are easy to solder because these bulbs have long leads which makes them easy to hold into position. You will not reuse the little plactic surrounds on the original bulbs.
