Plasti Dip experiment
Old Jul 24, 2012 | 03:42 PM
  #81
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Originally Posted by arrowhead
Do they make a gloss black spray?
Sort of......
With Plasti Dip Glossifier, you can give any Plasti Dipped item a glossy, polished look. Plasti Dip Glossifier is ideal for automotive applications, crafts, and many more uses.
Old Jul 24, 2012 | 04:20 PM
  #82
deathcharge's Avatar
deathcharge
Can this also be used to smoke tail lights?
Old Jul 24, 2012 | 04:25 PM
  #83
Racer's Avatar
St. Jude Donor '11
No, it is not transparent enough. VHT Nightshades is the best spray on smoke/tint in the business.
Old Jul 24, 2012 | 04:33 PM
  #84
deathcharge
I just wanted something temporary in case I didn't like it. I take it Nightshades wouldn't be removable?
Old Jul 24, 2012 | 05:43 PM
  #85
Racer's Avatar
St. Jude Donor '11
It comes off, but you need to be careful with what you use to take it off.
Old Jul 24, 2012 | 05:46 PM
  #86
ZICK's Avatar
ZICK
Originally Posted by dougj1985
I must admit this looks pretty good from something out of a can and that only take 3 hours.
I have a concern with its durability though. If it peels off so easily whats to keep it holding on when my tire is spinning at 6000RPM or when I wash my wheels or when debris from the road strikes my wheels. This may be just my inexperience with the product talking but I would hate to waste 3 hours of my time every time I wash the car to repaint my wheels.
They look good but your gas prices are crazy
Old Jul 24, 2012 | 06:00 PM
  #87
ZICK's Avatar
ZICK
Try PlastiDip Glossifier over it and will give you a glossy look
Old Jul 24, 2012 | 06:06 PM
  #88
mazurekd's Avatar
mazurekd
Their web site shows this:
http://www.dipyourcar.com/product.ph...&cat=21&page=1
They say gloss paint, not just the glossifier on top. I wish somewone would post pics if they used the gloss black.
Old Jul 24, 2012 | 06:26 PM
  #89
jimmie jam's Avatar
jimmie jam
I did the wheels on my CTS last week. Used Cammo brown with a dusting of the gold metalizer then finished with the glossifier. They turned out perfect with the white diamond tri coat exterior.
Old Jul 24, 2012 | 07:11 PM
  #90
360Rocket's Avatar
360Rocket
St. Jude Donor '12-'13-'14
Does it only peel off easy right after application or is it always easy to peel off? Wont this eventually come off?
Old Jul 24, 2012 | 08:00 PM
  #91
Racer's Avatar
St. Jude Donor '11
If you look at the picture, it is 4 cans of Black and 3 cans of glossifier.
Old Jul 24, 2012 | 08:02 PM
  #92
Racer's Avatar
St. Jude Donor '11
There is a video of them peeling it off after a couple of months, came off just like it does after being on 2 hours.
Someone here said it baked on in the Arizona summer heat and was hard to take off. But that was the only person I heard that from.
Old Jul 26, 2012 | 01:18 PM
  #93
mazurekd's Avatar
mazurekd
Yep, you are correct. My bad.
Old Jul 26, 2012 | 11:27 PM
  #94
droq172's Avatar
droq172
We shot my rims and door handles last week and I actually want to do the entire car in gunmetal grey.
Old Sep 14, 2012 | 07:39 AM
  #95
op z's Avatar
op z
Originally Posted by brucemc
Dipped my front and rear logos.
Tried the lisc frame that was chrome but not a fan of it. It just didn't come out the same.
Were the emblems removed prior to spraying or did you just mask of the emblem?
Old Sep 14, 2012 | 10:18 PM
  #96
brucemc's Avatar
brucemc
We traded PMs on this but just in case for anyone else.
I left them on, taped a large area around them and sprayed them with light coats for about 5 times. It has to dry before taking off the excess over spray or you'll pull some off the emblem.
Light coats, get the coating thick, and be patient.
Well worth the effort for the right car and look.
