Seafoam
Old Jun 6, 2012 | 01:56 PM
dazz44's Avatar
dazz44
Default Seafoam
Seafoam Good or Bad!!!!!!
Old Jun 6, 2012 | 02:05 PM
Eppieguy's Avatar
Eppieguy
I love it for my DD, 09 Tahoe, I put it in the gas and do a top end clean to it all the time, great stuff. I've put it in the gas of my Vette but never did anything else.
Old Jun 6, 2012 | 02:16 PM
Crowhater's Avatar
Crowhater
I have used it for years and swear by the stuff!
Old Jun 6, 2012 | 02:36 PM
Rogers 07's Avatar
Rogers 07
Used this in boats for years, Good stuff! Cleans fuel systems really well.
Old Jun 6, 2012 | 02:40 PM
boraxman's Avatar
boraxman
Good/
Old Jun 6, 2012 | 02:54 PM
bbudman's Avatar
bbudman
I've used it for years in my outboards on my boats. On my old 2 strokes it kept them running great. Now that I have fuel injected 4 strokes I don't worry as much and only treat the fuel if I am going to be out of the water for any amount of time and at the end of the fishing season. It also works great in lawn equipment like trimmers and blowers!
If your car sits up for extended periods or you don't drive it on a regular basis then Sea Foam is an excellent fuel stabilizer. For the daily driver it doesn't hurt to do a treatment on schedule with your regular oil changes and service.
Old Jun 6, 2012 | 02:55 PM
3rdWish's Avatar
3rdWish
Great stuff! Used it for years now. Lawn mower, leaf blower, weed eater, gator, boat, all autos and diesel tractor.
Old Jun 6, 2012 | 04:34 PM
Torchsport's Avatar
Torchsport
St. Jude Donor '15 thru '26
I've used it exclusively for decades.
Bikes, boats, mowers, cars, trucks, weed wackers, everything.
Scientists have shown that Sta-bil does not mix well with todays corn based fuel. It will gel.
Seafoam does a better job.
Old Jun 6, 2012 | 04:39 PM
R&L's C6's Avatar
R&L's C6
Old Jun 6, 2012 | 04:42 PM
RMB1234's Avatar
RMB1234
Cruising
Worked really well on my inboard outboard engine.
Old Jun 6, 2012 | 04:47 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
As others have said, I use it in everything that has an engine. Really good for anything with a carb. Small amount in each tank full. Several mechanics I know have cleaned up EGR valves and carb needles using S.F.
Old Jun 6, 2012 | 04:58 PM
MGP1's Avatar
MGP1
2020 C6 of the Year Finalist - Modified
Been using it 4 years on all engines...
Old Jun 6, 2012 | 05:10 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
So, this FAQ piece by Sta-Bil is wrong?
from here: http://www.goldeagle.com/brands/stabil/faq.aspx#5
"Q: What is the difference between STA-BIl Fuel Stabilizer, Marine Formula STA-BIL, and the new STA-BIL Ethanol Treatment products?
A: STA-BIL® Fuel Stabilizer is designed for use during STORAGE of any gasoline equipment or vehicle stored for 30 days or more, or used infrequently. It will keep gas fresh for 12 months, and help prevent corrosion, and gum and varnish formation. It is effective in all gasolines, including Ethanol blends, including E-85.
Marine Formula STA-BIL® Ethanol Treatment was designed for use at every fill up for marine engines (boats, jetskis) to protect against the damaging effects experienced when using Ethanol blended fuels -- including corrosion caused by water attraction, and fuel system plugging caused by deposit loosening.
New STA-BIL Ethanol Treatment is designed for use at every fill up for all gasoline automotive and small engines for protection against these same problems."
"Q: Is STA-BIL® Fuel Stabilizer safe for fuel injectors and catalytic converters?
A: STA-BIL® brand is safe to use in both fuel injected and carbureted engines, and will not damage catalytic converters or oxygen sensors. STA-BIL® Fuel Stabilizer prevents the formation of gums and varnish that can clog fuel injectors, and actually contains a fuel injector cleaner to further improve your engine’s performance."
Old Jun 6, 2012 | 05:32 PM
CaryBob's Avatar
CaryBob
I prefer the factory colors. It's a little too much of a foo-foo color for me.
Old Jun 6, 2012 | 05:48 PM
CWHPARTS's Avatar
CWHPARTS
Platinum Supporting Dealership
CARLISLE BLUE?
Old Jun 6, 2012 | 09:34 PM
JT Metal's Avatar
JT Metal
St. Jude Donor '12-'13
Good! Just don't gorge on any additive. Sleds, jetskis, cars, trucks, snowblower, etc, etc......
To Seafoam
