Zaino, what'd I do wrong?
As for ease of use, try the Clear Sealant. Apply it and walk away. Very easy to use. You don't even have to buff it. As with any product, preparation is the key. Once the surface is prepped you can do a one step with any of the Zaino products.
Clear Sealant and a finish with the Z8 spray Sealant gives a great wet look. One bad experience with Zaino shouldn't alter perceptions. Everyone I've turned onto it loves it. If you don't like it I'm fine with that too. You can send your Zaino products on to me
seriously, your story is 1 negative out of 1,000 positives. I don't know what went wrong. The steps are easy...the prep work is no more than the prep work that should be done no matter what product you use.....the difference is the other product manufacturers dont tell you to do that to get the best results...... Zaino does. The Zaino polymer layers, and its optical clarity is the highest available on the market ......
[/QUOTE]All I have to say is BS wolfie
- Car wash using Dawn liquid soap (the original blue color)
- Clay bar using Zaino Z7
- Re-wash with Zaino Z7
- To remove swirls, I have used 3M 39009 with great success, I use either the Porter Cable 7428 (Rotary) or 72424XP (DA) depending on the amount of swirls & cutting that needs to be done.
- Apply 1st coat of Z2 w/ZFX
- Buff with microfiber cloth after drying
- Wipe down with Z6
- Apply 1st coat of Z5 w/ZFX
- Wipe down with Z6
- Apply 2nd coat of Z2
- Wipe down with Z6
- Apply Z8, buff with microfiber cloth
- Finish with Zaino Clear Seal,
YOU GOT TO BE KIDDING ME. LIKE I SAID IN OTHER BRAND X THREADS, WASH, TURTLE WAX DETAILER, AND DRIVE THE DAM THING.
[IMG]http:
[/IMG]
Very straight forward, simple on/off. Deep shine. And can be layered.
I think I found my product - will keep using C-Magic.
With any product, a thorough cleaning and clay bar is best before starting. From there you can just use Z2 if you want. If there is much humidity it can take a while to dry. If it does not dry completely, no harm done it just takes a little more work to buff it out without leaving streaks.
I have not used Rejex and I'm not knocking it btw.
Assuming you were doing this in weather over 60 degrees F & with low humidity levels as it will effect cure times.
Detailing Steps
- Wipe down with Z6
- Wipe down with Z6
- Wipe down with Z6
- Finish with Zaino Clear Seal, some people may choose to apply earlier in the process, but I find it easier to apply once I am satisfied with the final results. The first time you do this, it will consume half a day, fortunately we have mid 70's to low 80's weather without humidity.
If your prep work is sound, you shouldn't have any issues with whatever product you choose to use, applying some type of paint protectant is better than nothing at all.
Common guys! If one person likes Zaino or Rejex or Adams or Turtle Wax... what difference is it to you? It is like arguing about whether a vette should be driven or stored in a garage. It is your car, enjoy your time with it the way you want.
The OP was asking for input on making Zaino work, so why not just let the other Zaino users chime in and help. Why all the negativity? I've used a few different products and like what I currently use, isn't that good enough? I would much rather listen to someone showing their positive results than someone bashing another person.
I do the same with Zaino Z5.
C magic is good stuff too.
As I said in the post, it sounds way more complicated than it actually is.
To each his own but you guys that have jumped in here and jumped on Wolfdogs should reconsider. Hmm, how about posting some pics of your rides after you wax them?
Op, sorry for your issues. As Lisa said, contact Zaino, they will help you out.
1. Prep is the same no matter what system you use. Dawn wash, clay, wash, polish the swirls if necessary, wash. None of that is Zaino! And all of it needs to be done before ANY "wax" for best results. (And only needs to be done the first time.)
2. Put on a coat of Z-AIO and you are finished, no real need for any other steps. IMO Z-AIO is about equivalent to Rejex and others all by itself.
3. If you wish to enhance the look add a coat of Z2 and, optionally, follow with some Z8 any time it needs a little touch up. Any more than that is unnecessary.
4 On dark colors additional coats of Z2 may further enhance the look, but add no more protection.
Once the paint is clean, apply some Z2 (use ZFX if you need it dry fast). Let dry. Wipe off. Drive car.
My paint looked great with Zaino...but I never took hours/days and 14 steps of Z-this, 12 layers of Z-that, rinse and repeat, or whatever.
If I was looking for a polish right now, I'd actually be scared off from using Zaino based on some of these posts. Unless your paint is in rough shape, you don't need to make this a part-time job to get good results.
Now I'm going to go stand in the corner for 10 minutes for posting in a Zaino thread...
I once got an email from him out of the blue thanking me for saying nice things about his products on the forum. First and only personal email I've ever gotten from a vendor. Obviously he follows the forum and there was no real reason for him to thank me personally. I thought that was a nice gesture.
Lay down your ZAIO next. From there follow up with Z2 or Z5 (some like both). I like Z5 on my black coupe. Use Z6 for a wipe down between coats. I usually only do 2 coats of Z5. That's really all you need IMO. The process is the same for pretty much any product for best results.
I usually use ZCS before a show and wipe down with Z8. Again not necessary at all.
So at a min. I suggest ZAIO at first and then Z5 and Z6.
