Need some guidence
Old Jun 12, 2012 | 07:24 PM
Dr No's Avatar
Dr No
Default Need some guidence
I am considering selling my 09 coupe with NPP installed and purchasing an 08. From what I have been reading, to use the NPP from my 09, I need to replace the crossover (x) pipe. Is this all that is necessary to use the NPP from my 09 on an on 08? Second question if so, where can I purchase the xpipe????
ajn
Old Jun 12, 2012 | 07:55 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Why would you sell your 09 to get an 08?
Old Jun 12, 2012 | 07:57 PM
Kiser64's Avatar
Kiser64
St. Jude Donor '12
Old Jun 12, 2012 | 08:00 PM
Dr No's Avatar
Dr No
091 LT1 Coupe for an 08 LT3 convertible.
Old Jun 12, 2012 | 08:47 PM
Scruff Vette's Avatar
Scruff Vette
I thought it had to do with a bend in the pipes. Check out how aftermarket, Corsa, Borla etc are sold. I know '05-'08 use a different exhaust than '09 & up. '08 is the only LS3 to use the earlier type bend.
The '05-'07 use a H-pipe configuration, the '08 and up use a X-pipe. I would check with a Chevy dealer or after market supplier.
Old Jun 13, 2012 | 08:59 AM
Top_Fuel's Avatar
Top_Fuel
Originally Posted by Dr No
...to use the NPP from my 09, I need to replace the crossover (x) pipe. Is this all that is necessary to use the NPP from my 09 on an on 08?
Yes...you are correct. Take the NPPs off of your '09 and track down a 2009+ mid-pipe. That setup should bolt right on to the 2008.
Keep an eye on eBay and the classified section here. There's not much demand for the stock mid-pipe...so you should be able to pick one up cheap (less than $100).
Old Jun 13, 2012 | 03:19 PM
Wildmanht's Avatar
Wildmanht
good choice
To Need some guidence
