milage turnback
#07-08-49-020E: IPC Odometer Programming Method Quick Reference Guide
Subject:IPC Odometer Programming Method Quick Reference Guide
Models:2003-2012 GM Passenger Cars and Trucks
The purpose of this bulletin is to provide a reference guide to help identify which season odometer programming method to use after replacing the instrument panel cluster (IPC). The three season odometer programming methods in use today are listed below. In addition, this reference guide lists the component where the season odometer value is stored. The season odometer value may be stored in the IPC, the driver information center (DIC) or the integrated body control module (IBCM), also commonly called a body control module (BCM).
Season Odometer Programming Methods in Use Today
Is there any possible way the milage can be turned back on a c6 corvette? Yes.
I don't know. Third base? Wrong again?
