Alignment question please
Old Jun 19, 2012 | 08:33 PM
vettemann62's Avatar
vettemann62
Default Alignment question please
I just had my C6 aligned but when driving straight the steering wheel is not straight. It is almost at the 1 O'Clock position. I always thought that when an alignment is done that the steering wheel position is readjusted to the 12 0'Clock position.
Old Jun 19, 2012 | 08:36 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
generally speaking, yes, it is adjusted. but sometimes, you have to ask for it. I'd say, bring it back and see what they say. I would hope they won't charge you for more service.
Old Jun 19, 2012 | 11:53 PM
florida john's Avatar
florida john
Should have been aligned with wheel centered. You are not being picky.
Old Jun 20, 2012 | 09:44 AM
RO55's Avatar
RO55
Old Jun 20, 2012 | 08:07 PM
cegusa's Avatar
cegusa
Steering wheel positioning is part of the toe adjustment in the alignment process. This being said, just cause the steering wheel is off center does not mean that that the alignment is off or incorrect however the alignment shop should address and adjust this for you to your satisfaction.
Old Jun 21, 2012 | 01:01 AM
2006c6keller's Avatar
2006c6keller
Default Simple fix!
Simple fix, turn both tie rod ends the same amount and direction and the steering wheel will center up and the toe-in is NOT affected. It will take them only a minute to do it, it the returning that is crappy. I have done this before on other cars BUT I could reach easily under them, not the Vette.
Old Jun 21, 2012 | 06:22 AM
bolivar's Avatar
bolivar
Alignment person screwed up.
To Alignment question please
