Shorter shifter???
Old Jun 22, 2012 | 09:35 AM
Shifter6's Avatar
Shifter6
Default Shorter shifter???
What would be the best way to shorten the shifter on my 05 C6 T56? I dont want a short throw shifter, I just want to shorten the shifter. I would like to use the factory **** as well.
I searched but only came up with info on short throw shifters.
Old Jun 22, 2012 | 09:41 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
You've sort of taken everyone's suggesstions out of play in your post. The two ways to get a shorter (or perceived shorter) throw from the OEM shifter is to install an aftermarket short throw like a Hurst or MGW shifter or to change out the OEM **** to a Hurst style ball type ****.
In order to keep the OEM **** and not change the shifter but still result in a shorter throw is going to require cutting the shaft on your OEM and then drilling and tapping in a new screw hole for the OEM ****. I don't know of any other options for what you want to do.
Old Jun 22, 2012 | 09:48 AM
CWHPARTS's Avatar
CWHPARTS
Platinum Supporting Dealership
if you dont want a aftermarket shifter and you want to use your stock ****, then your only option is to cut the stock shifter down shorter
there is no other way to do it , you could get a padded armrest for the center console so it will be taller, making the shifter seem shorter
Old Jun 22, 2012 | 09:52 AM
Sunset-C6's Avatar
Sunset-C6
Another option is the RSD snap shift......
http://www.racespecialtydesigns.com/...0&bestseller=Y
Old Jun 22, 2012 | 10:23 AM
Shifter6's Avatar
Shifter6
I just want to lower the shifter **** height relative to the center console lid. I thought about the cover, that is my backup plan.
Will a short thow shifter do this even if I use the oem ****?
Old Jun 22, 2012 | 11:16 AM
CWHPARTS's Avatar
CWHPARTS
Originally Posted by shifter6
i just want to lower the shifter **** height relative to the center console lid. I thought about the cover, that is my backup plan.
Will a short thow shifter do this even if i use the oem ****?
the aftermarket short throw shifters with the stock **** are very close to the same height as the stock set-up.
The easiest way to do what you want is change the **** or change the center console cushion
__________________
YOUR CORVETTE SUPERSTORE SINCE 1988
CORVETTE WORLD HOUSTON
281-821-1222
http://corvetteworldhouston.com/
Old Jun 22, 2012 | 11:19 AM
Shifter6's Avatar
Shifter6
Any shifter ***** out there that look like the factory one but are not as tall?
Old Jun 22, 2012 | 12:07 PM
RO55's Avatar
RO55
I used the ball which lowers it 1.5 inches which matches up perferct to use with armrest.
Old Jun 22, 2012 | 09:45 PM
Al Gumby's Avatar
Al Gumby
Shortens that crazy-long throw of the OEM set-up and feels good while doing it. One of the best things I've done to my Vette.
Old Jun 22, 2012 | 09:58 PM
dklowrider's Avatar
dklowrider
this is the only reasonable option if you insist on using the stock ****.
this is a WHOLE lot easier. but i'm an old school round **** kind of guy anyway. the lower shifting height is just a bonus.
and some words of wisdom if you go this route: be sure you know what you're buying. some vendors have universal fit ***** with plastic inserts to fit different shifters. the good ones have an o-ring for the boot and fasten just like the oem.
Old Jun 23, 2012 | 12:06 AM
brooklync5's Avatar
brooklync5
i agree with RO55 and have the same ball along with the mgw shifter
Old Jun 23, 2012 | 09:30 AM
CWHPARTS's Avatar
CWHPARTS
[QUOTE=dklowrider;1581139670]this is the only reasonable option if you insist on using the stock ****.
i use a stock style **** (dsv leather w/blue stitch) on my mgw that is my favorite set-up
Old Jun 23, 2012 | 11:01 AM
Maypo's Avatar
Maypo
Default MGW with Ball
Hey BrooklynC5 - This is exactly the setup I am thinking of purchasing. Can you give me a short review? What did you not like about the stock setup and what you like/don't like with this ball **** atop the MGW?
The "notchy-ness" of the standard shifter drives me a little crazy. My prior manual gearbox was a Miata (yeah, I know) that had a buttery smooth gearbox - wonderful around town and on the track.
Old Jun 23, 2012 | 02:50 PM
dklowrider's Avatar
dklowrider
[QUOTE=COHPARTS;1581142028]
well he did say he didn't want a short throw shifter, he just wanted to shorten the shift lever. so your option, which i would do (aftermarket shifter) was not a desireable option. hence the two options are: shortened stock shifter, or use a **** that effectively lowers your grip height without having to change shifters.
To Shorter shifter???
