When I purchased my 2005 vette the previous owner put the slightly worn original tires back on the car when he traded it in. I plan to go on a several thousand mile trip in the fall with the vette and am concerned a bit with the tires. While not even worn halfway yet the rubber to me seems a bit hard/shiny and although not cracking or having evidence of dry rot I'm thinking I should replace them for safety reasons. I have talked with some friends and surprisingly have had a mixed response.
Maybe I should have a bit of fun and wear the tires down then replace them , what do you folks think, am I pushing it a bit using these tires?
More than likely not. Depending on when the car was built the tires could be up to 8 years old. I doubt they have any dry rot as that seems to be more of an issue with tires that are 3 or 4 years older than yours. If your tires haven't seen a lot of sun exposure I wouldn't worry about it.
I also have an '05 (19K miles) with original G/Y's and I'm planning a 2K mile trip end of July and another 1K trip to Carlisle in August, tires are 7+ years old and fronts (rather strange) are worn more than rears. I'm changing to Michelin RF's next week. If you're staying local before your trip I'm sure the G/Y's will be fine but for a long trip I like the peace of mind of new tires under me. Maybe just me....
I would first have a Corvette tire guy check them out. All things considered you are probably OK to ride on the tires IF they ride good and perform well for you now. I cut corners saving $ on most things I buy except tires, brakes and safety stuff I don't. If you are having any second thoughts I would change them out for new. You will feel better about it when you exercise the 430+ horses.
The fronts wear faster than the rears. Same thing happened here at 44,000+ miles fronts were worn but rears were still good also on 2005 model. I replaced all 4.
I was told that if tires are over 5 years old replace them.
"Unfortunately no one is absolutely sure of how long tires will last because of the many variables. Heavily loaded tires on vehicles stored outdoors in sunny, scorching hot climates and only driven occasionally face some of the most severe service conditions and potentially have the shortest calendar lifespan. In contrast, lightly loaded tires on vehicles parked in garages and driven daily in moderate climates experience some of the least severe service conditions and potentially have the longest lifespan."
"The NHTSA tire aging field study also indicated a strong correlation of the speed rating with tire durability, with higher speed-rated tires losing the least capability with increasing calendar age."
"Our experience has been that when properly stored and cared for, most street tires have a useful life in service of between six to ten years."
From: Stafford VA, home of our wolf den. No house break ins to date.
Thanks for the responses, I am leaning toward replacing the tires, now the fun is deciding on a tire. I am considering the Michelin Pilot Sport A/S plus ZP, living in New England (CT) where the roads really are in bad shape plus the fact that I love to drive in the fall which means wet leaves and the need for All Season Tires. Anyone have these on their car that would care to share there experience or offer other options. Thanks again - Jeff
I installed those same tires last fall. Great tire! They have a 40,000 mile wear rating.
I'm getting them installed on my '05 on Tuesday, I too live here in the Northeast and I like the versatility of All Season, I don't track the car and I want the convenience of Run Flats, I got 2 flats with the stock G/Y RF's and both times I was able to limp home and get the tire repaired. PM me if you want more info, I'll let you know how things work out. BTW, I'm also getting the Tire Pressure Monitors replaced as the 7-10 year window for failure will come up while the new tires are on the car.
I put my Michelins on this spring. I've never had a bad Michelin tire.
I have had a bad set, and Michelin knew it (and it wasn't my four, it was an inherent, design flaw)--but that was a very long time ago. Considering Michelin America's response it took me a long time to go back to their brand. Actually, until the PS2ZP of '11 (I have a long memory).
If OP wants some more impressions, ck with Gearhead Jim re his experiences with the tire you're looking at, altho I think the general consensus is the A/S is a very good tire, maybe almost up to the level of Michelin's more "summery" tire, the PS2 ZP (but lasts longer than the PS2).
yeah, it was not out of brand loyalty but more they had what I wanted for the Vette and no one else did.....RF,A/S, warranty
A photo would help. I would replace them since your leaving on a long trip. Worn tires can be a problem in the rain if you're getting close to wear bars.
