Bug stuck in headlight
Old Jun 23, 2012 | 10:15 PM
Camss57's Avatar
Camss57
Default Bug stuck in headlight
So my dads 07 somehow has a large bug inside of the headlight. How do we get it out of there?
Old Jun 23, 2012 | 10:52 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
You ccan blast a little air between the Hi and Low beam bulbs and maybe blow him to the deeper bowls f the housing, Out of Sight Out of Mind... Or some have rigged a little vaccuum tube and worked it inbetween the same bulbs and sucked them out.
I personally have my second large bug sitting on my bezel. he's been there about a year now. We've became friends...
Old Jun 23, 2012 | 11:29 PM
Camss57's Avatar
Camss57
LOL! It's all the way in the front of the lens. I'll try to pull a b and see if I can get a smaller vac in there. If not, I guess I'll hit it with the compressor.
So the body colored part can be removed or can I only pull a bulb out?
Old Jun 23, 2012 | 11:36 PM
Bill Soda's Avatar
Bill Soda
Pull a bulb out will not allow access for a vacuum. Had the same problem with my '07. The only way to get mine out was remove headlight assembly and shake upside down. Not that big of a job. Google " remove c-6 headlight " that will give some pointers.
Old Jun 24, 2012 | 01:17 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Park the car in the sun and let the critter shrivel up and it's a little easier to vacuum/blow it out.
Old Jun 24, 2012 | 01:23 AM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
do a serch on Bug in Headlight. There's been a couple of members successful with vacing the bugs out. They rigged up a skinny tube and worked it past the bulb/projector into the headlight.
Body colored bezel cannot be removed while the light is together. Removing the rubber boot and bulb is about the most access you're going to get with the headlight in the car.
Old Jun 24, 2012 | 01:25 AM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
My buddy is just a shell of what it once was. Just the carcuss lying there in the inside corner on the bezel. If I had just a little more gap he'd fall down into the light. I'll be changing my lens in the near future and will take care of him then. But like I said I got the first one out and this one showed a month or two later. maybe an offspring...
Old Jun 24, 2012 | 02:02 AM
Knob Jockey
Admit it, you like having a 'pet'.
I keep expecting you to post a pic of a headlight assembly that you've turned into an aquarium.
The perfect South Beach accessory!
Old Jun 24, 2012 | 10:08 AM
Thrash's Avatar
Thrash
I had SOME success but not totally. I drove through a torrential flash storm last fall and one of the lenses fogged up, and the fog would not go away even after leaving in the sun. So I took off the well-liner and found the rear rubber HL cover had popped off. So I put a fan up to the opening and viola, fog gone ... but dust/dirt got in there (dohhh). So I taped a 1/4" rubber tube to a shop-vac and got it in through the low-beam gap (a PITA) and was able to suck out some but not all the debris.
Likely best to remove the HL and shake it out, and it's really not that hard to do. Just search HL Removal ...
Old Jun 24, 2012 | 12:49 PM
Camss57's Avatar
Camss57
I'll pull the headlight. Thanks guys!
Old Jun 24, 2012 | 03:30 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
Originally Posted by **** jockey
admit it, you like having a 'pet'.
The perfect south beach accessory!
:d:d
hmmmm....
To Bug stuck in headlight
