So How Much Will This Cost?
Old Jul 4, 2012 | 01:10 AM
RockyPM's Avatar
RockyPM
Default So How Much Will This Cost?
Was parked off to the side of a parking lot on Saturday and got hit and runned. Looks like the drivers side back was rubbed and pushed, it creased the rear side of the bumper moulding. Will this whole piece have to be replaced or can it be repaired? Here's some pics.
[IMG][/IMG]
Old Jul 4, 2012 | 01:13 AM
ScottJ03's Avatar
ScottJ03
To post pick you have to upload to a website like photobucket or facebook and copy image location. Click on pic icon above and paste address in there.
Hope that helps
Sorry to hear that.
Old Jul 4, 2012 | 01:26 AM
RockyPM's Avatar
RockyPM
Hope this works.
Old Jul 4, 2012 | 01:28 AM
RockyPM's Avatar
RockyPM
Thanks! So what do you think?
Old Jul 4, 2012 | 01:31 AM
ScottJ03's Avatar
ScottJ03
It could be fixed I think, but replacement would be better even if it it is not new parts.
Good luck, it could have been a lot worse!
Old Jul 4, 2012 | 01:35 AM
RockyPM's Avatar
RockyPM
You're right, could've been worse. Paint is alligatored above the crease. Taking to body shop friend tomorrow to see about cost. I'm with you in wanting it replaced. If it was hit enough to crease it what happened under the skin?
Old Jul 4, 2012 | 02:51 AM
bolivar's Avatar
bolivar
$2,500.
Old Jul 4, 2012 | 06:16 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
the bumper cover will probably need replacement which is not super expensive. I think the fender can be sanded and painted. cost, I don't know but I'd say it's a close split betw. parts and labor.
Old Jul 4, 2012 | 07:07 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
$1800
Old Jul 4, 2012 | 10:31 AM
bonnell's Avatar
bonnell
I got bumped on Friday the 13th on my front bumper (nose). It looked like yours but the driver side headlight lens had a tiny crack in it. I had the light and the bumper replaced with new GM parts. Thankfully it was completely cosmetic. mine we just under $3,000. The light assembly is $995!
Old Jul 4, 2012 | 10:37 AM
z51vett's Avatar
z51vett
Originally Posted by RockyPM
Hope this works.
If not for the wrinkle most of it will bluff out. I would try taking the bumper loose to see if wrinkle would come out use a heat gun to heat the area this is how some bumpers that a pushed in are repaired.
z51vett
Old Jul 4, 2012 | 12:30 PM
OnPoint's Avatar
OnPoint
The Consigliere
Good news it looks like its just the bumper cap.
Put a new one on or have on pulled from a vette in salvage with front damage.
You might fixing that wrinkle, but I would plan that to be your remedy. Probably be hard to make that go completely away, and you'd never be fully satisfied after investing time an money into it.
Old Jul 4, 2012 | 01:12 PM
Gman in NC's Avatar
Gman in NC
My daughter's BMW has similar damage to the front bumper cover. I had an estimate at a GM Collision Center. $571. They said that can put heat to the cover and get a wrinkle like that one out.
To So How Much Will This Cost?
