2007 Z06 question
Old Jul 8, 2012 | 09:16 PM
carbonite77's Avatar
carbonite77
Default 2007 Z06 question
I was installing my Varaam intake and put a hole in what ever is in front of the radiator and not the oil cooler. Does anyone know what that is?
Old Jul 8, 2012 | 09:30 PM
Swiftrider08's Avatar
Swiftrider08
A/C condensor. Your looking at a big repair bill.
Old Jul 8, 2012 | 09:32 PM
User 81424's Avatar
User 81424
Just put some JB Weld on it.
Old Jul 8, 2012 | 09:50 PM
carbonite77
I just ordered another one for 150$. Is it a lot of labor to install? It did have a lot of pressure in it.
Old Jul 8, 2012 | 09:51 PM
TJay74's Avatar
TJay74
Labor no, but time and money yes. You will have to get the AC system refilled again once you replace the condensor.
carbonite77
I just let it bleed out for about an hour or so. I couldn't stop it.
Old Jul 8, 2012 | 09:53 PM
carbonite77
Default AC Condensor
Well i need some other work done anyways ill just do it all at once i guess. Thanks for the quick response.
Old Jul 8, 2012 | 10:43 PM
tim414's Avatar
tim414
St. Jude Donor '12
You will need to repl the part you busted and then have the system evacuated and recharged (oil added if you lost any as well-for the a/c compressor)
Old Jul 8, 2012 | 11:34 PM
cclive's Avatar
cclive
The hissing sound was the sound of money escaping... Don't feel too bad though, it has been done many times by members here. Maybe they need to make the instructions more clear on that possibility.
Old Jul 9, 2012 | 01:21 AM
sublime1996525's Avatar
sublime1996525
I wouldnt think it'd be too bad right? Are you doing the work yourself? When I had a new engine put in my camaro they forgot to recharge the ac so I got a couple cans of the r134a and did it myself. Took only a few minutes to recharge. So replacing the condenser and recharging the ac and that should be about it right?
Old Jul 9, 2012 | 11:42 AM
cclive's Avatar
cclive
After the system has been open to the outside air, it needs to be evacuated and then have the right amount of oil and refrigerant added back. This takes expensive equipment.
Old Jul 9, 2012 | 12:12 PM
tim414's Avatar
tim414
St. Jude Donor '12
While I have not done it on the Vette, I did do it on the F-body I had.....this why I know
Old Jul 9, 2012 | 12:23 PM
tim414's Avatar
tim414
St. Jude Donor '12
If the system has any humidity/moisture (add: in the lines-it's a sealed closed system) then it could/will cause the system to freeze up especially in hot weather. Even more so if the system has correct charge. It will also 'likely' shorten the serviceable life of dryer/compressor as well as have no a/c while it's froze up/waiting for it to thaw out.
Old Jul 9, 2012 | 04:56 PM
carbonite77
Not doing the work myself. Im waiting for the part to come in. I hope any shop can install it.
Old Jul 9, 2012 | 05:00 PM
carbonite77
Now I'm getting worried about how much is it going to cost. Can any shop preform this or do i have to go to the Dealer and get beat up.
Old Jul 9, 2012 | 05:01 PM
carbonite77
Also the Condensor i bought has the dryer with it
Old Jul 9, 2012 | 05:13 PM
Cherokee Nation's Avatar
Cherokee Nation
Those Varaam's get Expensive,.,.Good Luck
To 2007 Z06 question
Old Jul 9, 2012 | 06:07 PM
carbonite77
Yea it is so far. I can't believe chevy made the shroud like that covering the intake. Any one here using the varaam on there car. How do you like it. Well even after this setback i couldn't even install it i have to wait. Im not to mobile around a car. I had a few surgeries. So I'm stuck with that big Stock sponge thats in the original intake. You know the way it is set up i found about 100 dead ants and ants with wings in my intake. Pretty nasty.
Old Jul 9, 2012 | 07:56 PM
pokerpro's Avatar
pokerpro
2021 C6 of the Year Finalist - Modified
2020 C6 of the Year Finalist - Modified
2015 C6 of Year Finalist
Oh so your the one who ruined the Ozone!!!
Old Jul 9, 2012 | 08:06 PM
tim414's Avatar
tim414
St. Jude Donor '12
Any place who does a/c work should be able to install repl part's and evacuate and charge the a/c system.
Did you find any oil in your intake?
