View Poll Results: Which tire?
275 (F) & 325 (R) - Michelin Pilot Super Sport
14
29.17%
285 (F) & 345 (R) - Michelin Pilot Super Sport
17
35.42%
275 (F) & 325 (R) - Nitto Invo
3
6.25%
285 (F) & 335 (R) - Nitto Invo
3
6.25%
Other
11
22.92%
Multiple Choice Poll. Voters: 48. You may not vote on this poll
Please Help with Tire Selection
Old Jul 10, 2012 | 11:16 AM
94boosted's Avatar
94boosted
Default Please Help with Tire Selection
Hi Guys,
The stock Good Year Supercars on my 2010 GS are nearly gone (at the wear bars in the middle of the front two) after only 5000 miles and two autocross events. So I'm obviously not going to get another set of those crapy tires. The plan is to get something a little better and maybe a little wider followed by an alingment to make sure the new ones don't wear prematurely. So here is my question to you GS & Z06 guys & gals that DD your cars and also do some autocross and/or mild track use:
I'm looking for a tire that I can get ~12,000miles (summer DD) & 12-15 autocross events out of. So basically a tire that is a good compromise between sticky and long life. So far the two that peak my interest are the Michelin Pilot Super Sport's and the Nitto Invo's..... which of those is the better tire for my needs? Any other tires I should really consider? Also what about size I know I can fit 275/35/18's or 285/35/18's up front and 325/30/19's, 335/30/19's or even 345/30/19's in the rear on the stock wheels, which size should I go with?
Old Jul 12, 2012 | 04:58 PM
94boosted's Avatar
94boosted
Bump!
Any help would be appreciated.
Old Jul 13, 2012 | 04:46 AM
judson whitley's Avatar
judson whitley
Default tires replacement
i to had to change front tires on GS 2010 with 5000 miles i switch to michelim pilot sport zp run flats have 10000 miles on them no wear plus they mcome with 20000 tread warranty the rears r goodyear still okay with 18000 miles the problem is the front end alignment comes from the factory on GS/Z06 set up for racing Hendricks corvette man 30 years experience change the alignment for normal driving so that has made a big difference for me, my tires was worn just like yours in the middle
Old Jul 13, 2012 | 08:54 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
Go with the Invo's.....I replaced the OEM GY's on my '05/Z51 couple of years ago & have been totally pleased. Much better ride....much quieter.....better grip.....and they're much less expensive than the Michelins.
Old Jul 13, 2012 | 08:58 AM
surburban99's Avatar
surburban99
Are the Nitto Invo's a runflat tire?
Old Jul 13, 2012 | 10:19 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Nope
Old Jul 13, 2012 | 10:41 AM
JoesC5's Avatar
JoesC5
And niether are the Michelin Pilot Super Sports.
Old Jul 13, 2012 | 12:31 PM
94boosted's Avatar
94boosted
Thanks for the tips guys
I know both the Invo's and the Michelin's will probably get me the 10K+ miles I want out of a set of tires, question is which of the two tires is stickier. As I do plan on autocrossing with the tires.
Also is there any issues with running 285's up front and 335's or 345's out back? Any rubbing? Is it worth it going to a slightly wider tire?
The day I get the new tires put on I'm going for an alingment for sure.
Old Jul 16, 2012 | 01:40 PM
94boosted's Avatar
94boosted
Need to buy the tires this week but still can't figure out if going wider is worth it, or if I should stick to stock width, and also which is stickier Invo's or Super Sports
Old Jul 16, 2012 | 01:59 PM
JoesC5's Avatar
JoesC5
I went with the Bridgestone RE050A runflats in the stock sizes. Great tires at a great price.
Old Jul 16, 2012 | 02:24 PM
Don-Vette's Avatar
Don-Vette
I'll be getting those next!!
Old Jul 16, 2012 | 03:27 PM
94boosted's Avatar
94boosted
Do you do any autocross or track driving or was this strictly a daily driver/commuter tire?
Old Jul 16, 2012 | 03:31 PM
jrsgraphics's Avatar
jrsgraphics
Cruising
Default Don't forget about our Korean friends.
I was running Kuhmo's MX on my 03. I found them to be bitey, quiet, and smooth. They were recently retired but the upgrade replacement is the Ecsta SPT. There is also another one above that for summer driving.
I know for a fact they make them in C6 rim size because I almost bought them for the 07 set of rims I just got.
I could really push them while cornering and wish I didn't have to switch. From the MX's with a 220 treadlife I got 7k miles out of them (They were less than half tread life when I got my vette used) and probably could have pushed another 1-2k of sporty driving. Check them out.
Aesthetically I also like the sidewall and tread design of both MX and SPT.
RIP my MX's
Old Jul 16, 2012 | 05:45 PM
JoesC5's Avatar
JoesC5
Just regular driving but I have run 160+ at Talladega on them(and they gripped better then the OE Supercars) and pretty hard at the Tail of the Dragon. If I did anything on the track, I would get a dedicated set of wheels/tires just for that purpose.
Old Jul 16, 2012 | 05:46 PM
snide's Avatar
snide
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07 thru '11
Get the round ones...
I have the Nitto Invo tires on my Z06 right now.
Old Jul 16, 2012 | 06:06 PM
Sunset-C6's Avatar
Sunset-C6
Round tires are the best
Old Jul 22, 2012 | 02:53 AM
icyteddy's Avatar
icyteddy
I just installed Michelins Super Sport and will NEVER go back to the Goodyear OE tires. Ride is smoother, quieter, handling is better and provides better traction then the goodyears. I went with 275 35 18 for the fronts and 345 30 19 for the rears. Could not be happier with the performance!!! I highly recommend the Super Sport! I also hear positive things about the Nitto Invos also but I chose the Super Sport due to Nittos not being carried by Tire Rack.
Also I recommend getting a 4 wheel alignment depending on your what specification for the use of your car.
To Please Help with Tire Selection
Old Jul 22, 2012 | 03:14 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
OP- I know you're pretty focused on tire width, but don't lose sight of the tire's overall diameter and the front to back relationship. If you stray too far from stock you can upset AH.
I have 275/35/18's and 345/30/19's. I was running Michelin PS ZP's (according to Tire Rack the only run-flat available in 345/30/19) but they are usually out of stock/back-ordered so I've switched to Nitto Invos.
Lighter, quieter, sticky and much cheaper. Got them at Discount Tire with a warranty and they do a good job of getting them on my car with no issues.
An alignment is a good idea too. I had the shop use the PFADT street specs (actually a little toward the track side of the settings) and had the car corner-balanced.
Old Jul 22, 2012 | 11:02 AM
sam90lx's Avatar
sam90lx
I just put on the Super Sports in stock sizes and could not be happier. Considered the bigger sizes but on some Vettes it just did not look right so I took the safe bet.
The tires are amazing by the way!
Old Jul 22, 2012 | 11:37 AM
Fly'n Family's Avatar
Fly'n Family
Running an Invo 275/345 on a 19/20 set-up on my C6 and am very pleased so far. Don't track the car, but do push it on our winding mtn roads and they are very grippy (is that a word?), smooth, and quiet. You can definately feel the extra rubber on the road - the 345's are healthy tires and it's nice to be able to put the power down and have some traction.
Read alot of good stuff about the SS's as well - don't think you can go wrong with either tire, although the Invo's will leave +/- an extra grand in your bank acct. Neither are ZP's.
