HELP on rear diff question
Old Jul 15, 2012 | 11:47 PM
ABVETTE86's Avatar
ABVETTE86
Default HELP on rear diff question
Hi everyone,
I have a C6 2006 Z51 with a 427 built iron block, 2008 C6Z rear diff and a transmission. The rear diff and the tranny are stock but my question is what can I do to make my rear diff stronger "without paying a built rear diff"? for example I have one of my friend gave me a suggestion with the a diff brace and after market tranny mount. So what do you guys thinks? and I would love to hear from
Old Jul 15, 2012 | 11:51 PM
tonysrep's Avatar
tonysrep
I would think if its good enough for a c6z that you would be just fine
Old Jul 15, 2012 | 11:59 PM
ABVETTE86's Avatar
ABVETTE86
Also I forgot to tell you that I have Twin turbo kit installed in the car and I am still breaking-in the engine. So my goal is 700-800rwhp and my motor is good for 1200+rwhp. So know what do you think ?
Old Jul 16, 2012 | 12:36 AM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Originally Posted by ABVETTE86
Hi everyone,
Leave it alone and you'll be fine. I put close to a 1000 low 10 second passes on mine at the track (LS7/A6/Z06 diff combo) before it needed rebuilding and even then the ring and pinion were still in excellent condition.
Old Jul 16, 2012 | 12:39 AM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Is that air under that front passenger side tire? With the stock rear end?
Old Jul 16, 2012 | 12:46 AM
Supporting Vendor
Yes it is as the car regularly pulls the front wheels off the ground. Yep, I'm running a stock Z06 diff.
Old Jul 16, 2012 | 01:25 AM
ABVETTE86's Avatar
ABVETTE86
Thanx Subfloor for sharing the info, you
Old Jul 16, 2012 | 02:19 AM
Easy Rhino's Avatar
Easy Rhino
Dayum that is impressive.
Old Jul 16, 2012 | 05:54 AM
ABVETTE86's Avatar
ABVETTE86
Old Jul 16, 2012 | 05:56 AM
ABVETTE86's Avatar
ABVETTE86
How many runs you have done? and how long you have been doing this man ?
Old Jul 16, 2012 | 12:46 PM
Supporting Vendor
I bought the car brand new in February of 2007 and started racing with it in August of that year. My times so far have ranged from a 12.8 that night to the 9.950 I ran with it in December of 2009.
I actually started racing way back when I was 18 with my 1970 Chevelle but only did it sporadically since then until I got back into it hardcode with the Corvette.
In total I probably have at least 2000 passes on the car but have gone through 4 engines, 8 transmissions, 5 differentials and one torque tube in the process. Oddly enough though I'm still running my stock original halfshafts which have close to 90K miles on them now.
Old Jul 16, 2012 | 04:58 PM
ABVETTE86's Avatar
ABVETTE86
Man this is sound so awesome it looks like a long journey with a lot of experience specially the 4 engines, 8 transmissions, 5 differentials and one torque tube . Good luck man, thanx for that impressive history and I hope I can see my self a 9's guy
Old Jul 16, 2012 | 05:03 PM
Supporting Vendor
Here's the 9 second pass in case you haven't already seen it before:
Old Jul 16, 2012 | 07:31 PM
ABVETTE86's Avatar
ABVETTE86
MAN!!!!!!!! THIS IS !!!!! Dayyyyym !!!!! what kind of mods are you running man? also I just wanna say keep up the hard work man
To HELP on rear diff question
