I have an '11 GS vert with the GM accessory wheel locks and in a collosal brain fart, I can't find the key chuck to get them off. I was sure I put it in the glove compartment but NOOOOOOOOOO !! I have searched everywhere but no luck. I am calling the dealer tomorrow since I need a TPMS serviced anyway. Any suggestions?
It's hell getting old and forgetting and losing stuff.
check with your dealership. there is a code in the folder of all your manuals and stuff. with that they can order a key for you. i found that out when my dealership lost my key. in my case i had a flat and didnt want to wait so i had the tire repair place remove my key lugs, they pounded on a socket and removed them, destroyes the lugs but i didnt want to wait.
I agree with trying to track down the key code card first. It may be in your purchase ducuments already, or maybe the dealer has a record of it. This is really the best way, as the Tire dealer hammer on gripper sockets, may slip, and cause wheel damage. While maybe a bit late now, I always order an extra key, to hang on the basement wall, along with a copy of the key card. The original key should have been stored in the car all along. By luck, my other car uses the same key and code, so would really have to bumble around here, to lose all of this.
I just ran into the same problem. Tried several auto parts stores and tire stores. No luck. I did the socket deal. Found a six point metric that was just to tight to fit over the nut. Hammered it on to the nut and backed it out. All four came off easily. Now, if I can just put the key to the new locks where I can find it.
I don't know about GM locks but most aftermarket locks are a one time deal...the key is non replaceable. I'd just drive a socket or lock remover on and junk them.
I haven't personally tried this but I'm thinking a "King Gator" Gator Grip socket *might* do the trick in a pinch. I have a regular Gator Grip that works well on odd shaped items I need to turn for whatever reason. I noticed recently they have came out with the King Gator that is larger in diameter. Just now I pulled up their web page and it appears that the King Gator might fit over a wheel lock (on items up to 1-1/4" in diameter) and the pins should extend into the crevices or around ridges of a wheel lock.
Really not getting this, as been using McGard locks for years, with no problem ordering extra keys. Transferred the same set of wheel locks to three seperate cars over time, removing them several times, on/off. They'll probably outlive us all. Don't think removing hardened wheel locks is all that easy of an affair, even with special gripper sockets. Surely it can be done, but usually involve's lots of hard/noisy hammering. Kinda think, this may cause some attention in a quiet driveway at 2 o'clock in the morning.
Why make it easy for someone?
I have never seen a wheel lock that didn't have a registration form with a key number.
I have always attached my key to the lug wrench with a zip tie. But with the Corvette with no spare or jack I keep it in a bag with my jacking pucks.
Don't know about to today but years ago wheel locks did not have that many different lock configurations.I can remember my first set took a regular key and we found out just about any keyif it would fit in the opening would unlock them.
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Originally Posted by OMG
So are these any different from the C5 locks with weird 5 star pattern?
Also does the C6 have a special spot like the C5 for the key? (Between the two rear compartment doors)
Wheel locks are not a factory item. GM brands various locks that dealers sell for a little extra profit. Since they are not a factory item any more there is no specific place to keep the key.
quite a few GM dealers have sets of master keys for our wheel locks. had flat at home in garage and went to dealer 4 or 5 blocks from home and asked to borrow. dealer was good enough to lend them to me. Cliff Mills Pontiac Buick, Oshawa Ontario
