Under engine cleaning
One of our sponsors on here, Adam's, has a series of videos on detailing and they filmed it using the vette.
They have a segment on engine detailing, check it out here:
Engine Bay Cleaning
Edit: Adam's is now the officially licensed car care product for corvette and camaro
Engine Bay Cleaning
Adams does it with a standard garden hose and a nozzle. He recommends (at least on an older video) to have the engine running and move the water stream away from the point you are at if the engine stumbles.To answer your question, I would talk with a good detailer as already mentioned that does Corvette's. Ask if he does it with high pressure or just a hose.
Engine Bay Cleaning
Now if I only had a lift so I can get to the underside!
The two separate brushes are great. The use of wheel woolies for tight spots can be very helpful too!
I have not covered the alternator - but then I don't directly flood the alternator. But I also understand the reasoning and philosophy behind the "better safe than sorry" approach of covering the alternator too.
I agree that a lift would be nice. Was just checking tire wear the other night and was noticing the undercarriage could use some love.
Once you have the engine cleaned it doesn't take too much work to keep it looking good
I want it to look like this! What is the spray can product, can't see it on my phone?
1. Towel off around the engine bay to prevent overspray.
2. Wrap electronics in saran wrap.
3. Mix 50/50 Water and Simple Green in a spray bottle.
4. Spray down the engine bay and let it sit for a bit to break up the grime.
5. Use a pipe-cleaner style brush to get into the hard to reach places. Majority of the time, I do not have to brush down anything else cause the dilluted simple green mix does a great job on its own.
6. Afterwards, use a garden hose with a soft spray to rinse off the cleaner. Repeat previous steps if not completely clean. Can also use a brush if needed. Tooth brushes work good too.
7. Once it is all rinsed off. I let it dry in the sun.
8. After it is dry, I spray some WD40 on some blue shop towels and wipe over rubber hoses other plastics. Can use engine dressup as well. I don't directly spray that stuff on there though.
To clean the engine like you see it I used Adam's All Purpose Cleaner with the Boars Hair Brush and Lug Nut brushes for the smaller areas
To dress the engine area I used two different products:
1) Super VRT (Vinyl Rubber & Tire) - Otherwise known as SVRT.
Super VRT
This is a thick liquid used on an applicator. It resists water and has an SPF characteristics also. In the engine area I will use it on any large plastic or rubber surfaces. It is also great on any of the other exterior plastics on the car and the tires too. A tiny bit on plastic goes a long way. On tires, it does not fling off.
2) In & Out Spray
In & Out Spray
This is sprayed on areas that are too difficult to apply SVRT, little hoses, electrical connectors and even on areas like the front grill or the cowling. Makes the plastic look like new.
Remember that Adam's is now a CF sponsor. They also have a discount code for us to use too!
