fob programming failed
I had the same issue (1 fob), bought 2 at the dealer for $90 ea. and they programmed for a 1/2 hour labor charge.
you tried steps 1 - 10 here... right?
http://forums.corvetteforum.com/c6-c...tructions.html
you had car in park/reverse.. right?
your car is a domestic and not canadian/european.. right?
Originally Posted by cclive You can do it yourself. The short procedure will add it to your car and it will probably end up being Fob # 3....or you can do the long procedure, erase all and then program the two that you have as #1 and #2. Here are the two procedures :C6 Fob Programming, Simple short programming instructions. You use these instructions when you have a working fob and just want to add another fob to the system.
1. Car off
2. Trunk open
3. Glove box open
4. Put working fob on console next to shifter (the one you are currently using to drive the car) IMPORTANT. Also make sure no cell phones are in the car.
5. Put key in trunk keyhole and turn key five times in less than 5 seconds.
6. DIC will now beep (not always) and light up and say “Ready for fob 3”.
7. Put new unprogrammed fob in slot by glove box with buttons facing right (passenger) side.
8. Wait and watch DIC. When it says “Ready for fob 4” it is done. Up to four Fobs may be programmed to the car total.
9. When all Fobs are programmed, push OFF/ACC (bottom half of start button) to turn off DIC.
10. Test all four buttons on fob and then take away all other fobs and check car starting with new fob(s).
I would also use the long version to remove any existing FOBs you don't know about.
EDIT: Are you sure the slot is working?
"Once you have proved that the slot is working, you should be able to re-program using the long procedure without much worry.
Basically the check of the slot involves starting the procedure to add fob#3 and then presenting an already known fob to the car. If the slot is working, the car will say "KNOWN FOB". The only way the system can do that is through the slot...not from just having the fob in the seating area of the car...ergo, slot works. So read and follow that procedure and then you can go to the long procedure which will wipe out all fobs and let you start anew. The reason that checking the slot is important is that if you start the LONG procedure and then the slot isn't working, you will have wiped out all fobs and then will have no way to re-program them back into the system."
>>C6 Fob Programming and Glove Box Slot Testing Procedures<<
Aftermarket radios can cause an issue when you try to get into the programming mode. The radio triggers a code that the radio security feature is not talking to the ECM properly. If you have an aftermarket radio and did not buy the harness for the door beeps and OnStar, you might NOT be able to get into programming mode.
Elmer
1. Car off
2. Trunk open
3. Glove box open
"To make sure that the glove box slot is working, follow steps 1-6. Then in step 7 you insert one of the fobs that is currently programmed to the car into the slot. If the slot is presented with a fob that is ALREADY programmed to the car, the DIC will say “Known Fob”.
This shows us that the slot is working correctly by recognizing this fob. Push the bottom half of the start button to end the session if you were just testing the slot for proper operation."
