VIN Numbers
Old Jul 27, 2012 | 11:10 AM
murf257's Avatar
murf257
Default VIN Numbers
Not sure in I have this listed in the correct place or not but here goes; I am looking at a 2007 Coupe, I have the VIN # and want to find out what was ordered on it from the factory. Is that possible to do? If so, how do I go about that?
Old Jul 27, 2012 | 11:15 AM
unixcorn's Avatar
unixcorn
http://forums.corvetteforum.com/vindecoder.php
Old Jul 27, 2012 | 11:16 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Sounds like me. I just traded my '01 for an '07 3LT and wanted to find out that info. Found this site and it is spot on. I first tried my VIN from my '01 just to see and it was perfect. You can only do one VIN a day however unless you pay a fee. Here is the link http://www.compnine.com/vid.php
Old Jul 27, 2012 | 11:18 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Originally Posted by unixcorn
The VIN Decorder is not even close. I did my '01 as well as the '07 I ended up with and both came back as base models. My '01 was 2SC and the '07 is a 3 LT.
Old Jul 27, 2012 | 11:26 AM
unixcorn's Avatar
unixcorn
You could always pay $45 (non-member) for a build sheet from NCM....
https://store.corvettemuseum.com/ser...buildsheet.asp
Old Jul 27, 2012 | 12:01 PM
rodknock's Avatar
rodknock
Just ran my VIN [http://www.compnine.com/vid.php ] and came out dead on.
Old Jul 27, 2012 | 12:45 PM
Vette_DD's Avatar
Vette_DD
It evidently does not list options. Didn't list my chrome wheels or my NAV or my A6 or my dual mode exhaust.
Old Jul 27, 2012 | 12:49 PM
HighVelocity's Avatar
HighVelocity
Cruising
Look at the inside of the glove box door for a list of options.
HV
Old Jul 27, 2012 | 01:04 PM
Vette_DD's Avatar
Vette_DD
HV
OP may not have easy access to the glove box. He's asking about a car he's looking at.
Old Jul 27, 2012 | 05:50 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
The GM IVH (Investigate Vehicle History) report (formerly VIS) should show a list of the options at the end of the report. Gene Culley at GMPartsHouse.com, some of the Forum dealers, and your local dealer can run it for you.
Old Jul 27, 2012 | 07:53 PM
mpuzach's Avatar
mpuzach
Nah, it's nearly useless. All it shows is generic info for the model, nothing about how the specific car is optioned or configured.
Old Jul 28, 2012 | 03:28 AM
HummelS's Avatar
HummelS
Or open the glove box door and write down the build codes. Or if you have a friendly service manager in a GM store, ask for the GM-VIS report.
Old Jul 28, 2012 | 04:17 AM
HighPro's Avatar
HighPro
Go to the local dealer and ask the maintenance guys to run a report. It will take them two minutes and they should be happy to do it for free.
Old Jul 28, 2012 | 06:55 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
This one really works! In '08, negating the options, there was only one car, mine, made in the exterior, interior and top color! wow.
Old Jul 28, 2012 | 08:11 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Since the factory doesn't publish option combination production numbers, the compnine "rarity" is only a statistical calculation and, therefore, meaningless. If all white cars produced have a white top and all black cars have a black top and half the cars are white, compnine would say only 25% of the cars have a white top and a white body. Combine that with the factory production week "option" and if your car doesn't show as unique on that site then it is VERY common. That doesn't mean there aren't a lot of unique cars out there. Just that it is almost impossible to prove and compnine is just guessing.
And, BTW, the corvetteforum vindecoder IS totally worthless as stated above. It will give you the specs for the base car of that year but that is all. If all you need to know is that the car is either a Corvette or a Camaro then MAYBE the vindecoder would have some value but beyond that it is a total waste of time.
The way to know for sure what a specific car has as well as maintenance records is to go to any GM dealer and request a VIS report. That is a record of the manufacture as well as all maintenance/warranty done by GM dealers.
To VIN Numbers
