Wheel Nuts
Old Jul 27, 2012 | 03:15 PM
how2222's Avatar
how2222
Default Wheel Nuts
Just took of my wheels and the lung nuts werer so tight i need to stand on them to get them off is this normal. Any one knows how tight to make them .
Old Jul 27, 2012 | 03:21 PM
Don-Vette's Avatar
Don-Vette
When I have work done,I always tell them I want the lugs done by hand, not with the impact gun.
Old Jul 27, 2012 | 03:25 PM
BigJoe's Avatar
BigJoe
100 ft lbs Here is a good thread.
http://forums.corvetteforum.com/c6-c...ut-torque.html
Old Jul 27, 2012 | 03:59 PM
Orange05_C6's Avatar
Orange05_C6
Originally Posted by BigJoe
Just put my rims back on, torque wrench to 100ft lbs. Don't forget the copper never-seize for easier take offs next time
Old Jul 27, 2012 | 04:07 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Proper torque setting is 100 ft lbs....also use a dab of anti-seize lubricant on each stud. Don't use an impact wrench (air or electric) unless you check with a torque wrench.
Old Jul 27, 2012 | 04:16 PM
Orange05_C6
i still wouldn't use a impact gun. its too easy to over tighten and its easier to scratch or damage your lugs with them. But thats just me.
Old Jul 27, 2012 | 04:37 PM
EXPIM's Avatar
EXPIM
When using grease on the stud threads be aware the effect it has on the torque.
http://www.engineeringtoolbox.com/to...ts-d_1693.html
Old Jul 27, 2012 | 04:59 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I was told a long time ago you could get a false reading by using any form of lube.
Old Jul 27, 2012 | 05:03 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
http://<b>http://www.engineeringtool..._1693.html</b>
The last post is most important, putting any kind of lube on the lugs and then tightening to 100 lb/ft will be seriously over-torquing. People usually get away with it, but that doesn't make it a good idea.
If you have a beater that you drive through salty winter, and only take the wheels off every 40k miles for new tires/brakes, then removing the nuts might be a problem. On our Corvettes, they've always come off easily even when i did drive in winter.
EDIT-
Bill beat me to it!
To Wheel Nuts
