Sunvisor Extensions
Old Jul 28, 2012 | 06:26 PM
jarmst's Avatar
jarmst
Default Sunvisor Extensions
Checked previous threads and could not find a recent post for C6's. Has anyone located a sunvisor extension that works good? Trying to find something similar to a slide out in other cars to block the sun behind the rear view mirror or the far back of the side window.
All I hear from the wife is, "My Malibu has them, don't you think your more expensive toy would have them too?"
I've seen something called Visormates on the Internet, but as narrow as the Vette visors are, I am not sure they would fit right.
I realy don't want to get a clip on kind with the tinted plastic, looking for something a bit more stable and less likely to fall off (or fly off if the roof is open).
Old Jul 28, 2012 | 09:05 PM
ChevyDave's Avatar
ChevyDave
i have also been looking around and have found nothing as a replacement that has an extension.
Old Jul 28, 2012 | 09:40 PM
rz2mbc's Avatar
rz2mbc
This would be a good find.........
Old Jul 28, 2012 | 09:48 PM
adrnln1's Avatar
adrnln1
I just tint the top of the windshield down to where the visors reach, no need for visors
Old Jul 28, 2012 | 09:55 PM
rcallen484's Avatar
rcallen484
I only use the visors when necessary to see because I am headed into the sun. Otherwise they are up so as to not obstruct my view. How does that work with permanently tinted windshield?
Old Jul 28, 2012 | 10:15 PM
adrnln1's Avatar
adrnln1
I have done it on all of my cars for the past 15 years, at 5'8" the visors never helped enough. No obstructed view as its only the top 12"
Old Jul 28, 2012 | 10:19 PM
rcallen484's Avatar
rcallen484
Doesn't that obstruct the view out of the top 12"? As I said, I keep my visors up so there is ZERO obstruction UNLESS the visor is absolutely needed.
Old Jul 28, 2012 | 10:24 PM
gilhuly's Avatar
gilhuly
My long gone 85 S10 had slide extending visors, wished many times my 09 C6 had them
Old Jul 29, 2012 | 07:14 AM
Don-Vette's Avatar
Don-Vette
I have never used a sun visor in any car,just good sunglasses.
Old Jul 29, 2012 | 08:24 AM
capehorn3's Avatar
capehorn3
Also looking, my problem is the side window is not covered all the way to the rear, yes its tinted at the max allowed by law.
Old Jul 29, 2012 | 03:17 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Normally I don't wear one, but a ball cap works well when the sun gets in my eyes.
Old Jul 31, 2012 | 09:48 PM
adrnln1's Avatar
adrnln1
No issue at all, I don't like wearing sunglasses. Top 10-12"
Old Aug 1, 2012 | 12:31 AM
orca1946's Avatar
orca1946
I know they try to save pounds BUT for pete's sake make the damn things longer so as to block the sun for those of us that are taller than 5ft 2 !!!!
Old Oct 13, 2012 | 10:48 AM
vdavenp802's Avatar
vdavenp802
Its an old thread, but needs to be revisited since no solution was mentioned, only advice on how not to use the visor.
I was thinking about some form of slip-on type cover that when the need for some shade form the side window, just slide the cover out a bit.
I'm going to fabricate a prototype and post pictures here, for comments.
If for some reason you don't use or like the visors then you don't need to comment.
To Sunvisor Extensions
