help,had enough
Old Jul 29, 2012 | 10:57 PM
LMB-Z's Avatar
LMB-Z
Take it back to where you bought it and let them fix it under warranty. Then go take some typing and spelling lessons.
"and it runnung real rough", (and it was running real rough)
"I was only two mile" (miles)
"this is my secong problem" (second)
Just trying to help.
Old Jul 29, 2012 | 11:11 PM
All2Easy's Avatar
All2Easy
Same thing happened to me on my 2012 GS.....loose plug wire.
Old Jul 29, 2012 | 11:14 PM
JoesC5's Avatar
JoesC5
Originally Posted by St.Char
This usually happens with telescoping wheel, if you turn the car off and start it again, usually it will correct itself. However, the problem is with the wiring harness in the column getting pinched, there is a TSB for the problem, I occasionally have the same issue with my '05, there is a small comb like divider the dealer installs between the wires to correct it. I just dread going to the dealer to get it fixed. The part itself is only .79 cents.
This--->http://forums.corvetteforum.com/c6-c...-handling.html
I think that problem was identified and fixed by the engineers and Bowling Green by the time the 2010's rolled out.
Old Jul 30, 2012 | 07:57 AM
bonnell's Avatar
bonnell
Originally Posted by roosterocks
sorry about the 2020 didnt realize i wasnt as sharp as you
No problem Rooster. We all make typos. I certainly make my share.
Wow, I'd be upset too! As others have said, it is probably something quick to diagnose. Just take it to your dealer and let them take care of you.
Good luck and welcome to the forum.
Old Jul 30, 2012 | 08:04 AM
Don-Vette's Avatar
Don-Vette
maybe some one can help me. I just bought a 2010 gs with 2,700 miles. i took it out today and stopped to get a bite. when i restarted the check engine light is on, also says service traction control and service active handling, and it runnung real rough. I was only two mile from home so i took it slow and parked it. I want to blow it up, i just bought it 9 days ago and now this is my secong problem. Any suggestions whats wrong or how to fix this
Yeah this should fix it....
Old Jul 30, 2012 | 09:26 PM
roosterocks's Avatar
roosterocks
want to thank you for your help, 3lzzo6 you nailed it. I had a plug wire off. is this common wiith vette's? a few others said the same thank you as well
Old Jul 30, 2012 | 09:29 PM
darbn's Avatar
darbn
Originally Posted by SpryGeezer
Many 2020 model year cars had defective flux capacitors.
Old Jul 30, 2012 | 09:40 PM
CaryBob's Avatar
CaryBob
as far as my spelling, it is fine, it takes me a long time to type a message
We get it. But you should understand that making the effort to put together a good clear post about your problem is the best way to get good responses. When we see posts with a lot of mistakes, we don't usually think "big fingers" but rather "sloppy effort". Don't take it personally, just trying to help.
Old Jul 30, 2012 | 09:46 PM
JJPonzini's Avatar
JJPonzini
This is too weird. I just left a restaurant as well and my check engine light came on too. Solar flares maybe... Like the op, 2010 with 2100 miles. Runs ok though. Checked the gas cap and its ok. I guess the next step is call the dealer and schedule a service appt.
Old Jul 30, 2012 | 09:50 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
Did you read post #22 ?
The OP found he had a loose spark plug wire.
JKbride's Avatar
JKbride
W. GA Events Coordinator
St. Jude Donor '12-'13-'14-'15
Glad you found the problem, when the Websters Dictionary crowd shows up most of the time it's because they have little mechanical aptitude...otherwise they would help as others did.....just ignore them.
Old Jul 30, 2012 | 09:51 PM
ncvette_1FUNRIDE
OP, glad that you found the problem and it was an easy fix.
Old Jul 30, 2012 | 10:00 PM
  #33
JJPonzini's Avatar
JJPonzini
I looked at the plug wires and all looks well but was waiting for the engine to cool before I stuck my big hand down there to check if they were loose. The engine ran fine on the way home and idles smooth. I'm hoping just a plug wire...
Old Jul 30, 2012 | 10:27 PM
  #34
roosterocks
lol thank you
Old Jul 30, 2012 | 10:59 PM
  #35
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Glad you found/fixed your issue.
This Forum is a great source for first hand experience in problem solving.
Congrats on your "new" car.
Old Jul 31, 2012 | 10:22 AM
  #36
09Z06pj's Avatar
09Z06pj
Veteran: Marine Corps
ZR1 owner to the rescue!
OP, glad your car is fixed. Now you can go enjoy it!
Old Jul 31, 2012 | 10:32 AM
  #37
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Yeah, seems to be somewhat common.
To help,had enough
Old Jul 31, 2012 | 10:36 AM
  #38
SilverScorp's Avatar
SilverScorp
This happened to my 2010 GS as well. The problem was a defective accelerator pedal sensor that communicates with the throttlebody. It was fixed under warranty.
Old Jul 31, 2012 | 10:46 AM
  #39
Raazor's Avatar
Raazor
Goon Squad King of Battle
St. Jude 15 Year Donor
St. Jude Donor '08 thru '23
Here's an idea: Service the Active Handling
/thread
Old Jul 31, 2012 | 01:10 PM
  #40
Vette_DD's Avatar
Vette_DD
Just a reminder:
The Forum should be a place where we treat one another with civility so that it remains a fun and friendly place to hang around with other Corvette enthusiasts. Hostility to others is rude and inappropriate.
Personal attacks cannot be tolerated. Attack ideas, not fellow Forum members.
