Battery question
Old Aug 4, 2012 | 10:27 AM
LS14ME2's Avatar
LS14ME2
Default Battery question
Just picked up an '07 which still has the original Delco battery... on borrowed time... but no issues yet...
I have heard Autozone has a good battery... anyone use them?
Last red top Optima I bought for my Trans Am was DOA... trying to stay away from them...
Other thoughts....
Old Aug 4, 2012 | 10:32 AM
owebo's Avatar
owebo
St. Jude Donor '11, '16
My '07 still has the original battery....putting the load tester on it, it's really strong...but I do keep an eye on it....
When it goes to vette heaven, I will most likely get an interstate to replace it.....
dvilin's Avatar
dvilin
Why not stick with the OEM battery they seem to do the job and last a good amount of time. Yours is still good and that is 5 years old. When mine goes that is what I plan to do.
Old Aug 4, 2012 | 10:52 AM
kev1949's Avatar
kev1949
Johnson Controls manufactures Optima and many other auto store and Walmart battery brands.Replaced the delco in my c5 with a Walmart ,great battery for the money. OEM delco in '08 c6 no problems so far.
Old Aug 4, 2012 | 10:58 AM
Mad*Max's Avatar
Mad*Max
I put in an AC Delco for about $105, has been pretty good. My original lasted five years and I replaced it before it died.
Old Aug 4, 2012 | 11:10 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Other thoughts....
red tops are garbage , everyone I know has had problems with them . Stick with delco or excide orbital
Old Aug 4, 2012 | 12:11 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
I have heard the of OEM's lasting 7 years. Are you on borrowed time?? anyones guess. If it were me I'd replace it with either another Delco or Interstate.
We replaced the battery in our S-10 Blazer with an AutoZone top of the line battery. When we traded it in that battery had been in for over 6 years and was still going strong.
Old Aug 4, 2012 | 12:30 PM
C6ToGo's Avatar
C6ToGo
Advance Auto batteries are made by Johnson Controls like Zone, Delco, most Walmart and with promo code raf7ja1102 ($35off) it is 90 bucks for a Group 90. That is the one I plan to get when mine dies.
Old Aug 4, 2012 | 03:02 PM
LS14ME2's Avatar
LS14ME2
I had an exide orbital select (AGM) in my 2001 TA... It was a great battery.... replaced it after 10 years!! still pretty strong even then.
They are hard to find now....
Old Aug 4, 2012 | 03:09 PM
owebo's Avatar
owebo
Your being in Toronto, I would agree with you...my being in the states, the last thing I want to do is give my government more of my hard earned money......
Old Aug 4, 2012 | 03:13 PM
Eritosthenes's Avatar
Eritosthenes
The OEM battery in my very early '07 lasted 39 months. I replaced it with a Yellow Top size 35. It's a DD and I've had zero trouble with it. The few times I do park it for extended periods I connect a Battery Tender Junior.
Old Aug 4, 2012 | 04:02 PM
Mad*Max's Avatar
Mad*Max
you probably have much more selection/choice than us too
Old Aug 4, 2012 | 07:48 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I agree w. Dave. Also, get yourself a battery "maintainer," like a Schumacher, Battery Tender, C-tek, Harbor Freight, Sears, etc. And use it!
I use mine anytime I'm not going to use the car for a couple or more days. Mine is a Ctek and has (and my older Schumacher had it, too) the plug in connection for the dash/cigar lighter, so it's super-easy to use, to see that it's connected (no driving out of the garage w. it still connected! ), and works!
I replaced my July, '07 batt. this spring w. another Delco just to be safe. And fwiw, I just read a post about a fellow who had an issue w. a new Duralast.
FYI, It is VERY EASY to use the "search" button in the above red band: just hit search, go to advanced search, plug in a key word in the upper left (like "duralast"), hit time for say, last 3 months, hit C6 Gen for where you want to search, and VOILA!)
Here's the thread on Duralast at AutoZone; you decide if the battery/store works for you.
http://forums.corvetteforum.com/c6-c...tery-help.html
To Battery question
