Carbotech Brake Problem
Old Aug 6, 2012 | 02:29 PM
alamo1974's Avatar
alamo1974
Default Carbotech Brake Problem
Installed the carbotech CT1185 brakes on my 2012 GP yesterday and the brakes work great - BUT when stopping say from under 20 mph to stop they make a loud schrecking sound. Any ideas what I might have done wrong????
Old Aug 6, 2012 | 03:04 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Please call me at 2167808825
Old Aug 6, 2012 | 03:31 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
is there a bedding in process explanation that came with the product?
Old Aug 6, 2012 | 04:36 PM
Carbotech Adam
Supporting Vendor
Proper bedding instructions for the Bobcat 1521 Compound :
1.Brake from 60mph down to 30mph about 4-6 times.
2.Then let your brakes cool for about 2-3 minutes while driving.
3.Repeat step # 1.
4.Allow the brake pads and discs to cool down to ambient temperature (about 30 minutes or more).
NOTE: Proper bedding of pads & rotors will result in greater performance and longer pad & rotor wear.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Aug 6, 2012 | 04:39 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
Yes, there is. Multiple (6 or 7) hard stops from 60 mph down to 20 mph when you first put them on.
I have carbotech pads and I get a slight screech sometimes when I hit the brakes lightly when going slow 5-20 mph.
Old Aug 6, 2012 | 07:41 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Mine are doing the same and the bed in procedure was done ... Slight screeching under 10 mph . Performance is fine. The dust is a little better .. I have about 900 miles on mine
Old Aug 7, 2012 | 04:24 AM
alamo1974's Avatar
alamo1974
I'll call Adam at Carbotech, I did the proper beeding per instructions. When the brakes are cold, there is no noise but once the brakes get warm they start screeching and it's a loud sound .
Old Aug 7, 2012 | 03:34 PM
ebf2k's Avatar
ebf2k
St. Jude Donor '12-'13-14
Mine squealed really bad at first until I put the anti-squeal grease on the backing plates. Now they are totally quiet.
Old Aug 7, 2012 | 08:34 PM
user051728's Avatar
user051728
My 1521's on the Corvette rarely squeak, and when they do it's slight and only brief.
My AX6's on the GTO are obnoxiously loud...
Old Aug 7, 2012 | 08:40 PM
VETFEVER's Avatar
VETFEVER
Yup
Old Aug 7, 2012 | 10:28 PM
Carbotech Adam
Supporting Vendor
Please call me.
Old Aug 7, 2012 | 11:41 PM
alamo1974's Avatar
alamo1974
Originally Posted by carbotech adam
Please call me.
Adam, I was out of town today and will call you tomorrow morning.
Paul
Old Aug 8, 2012 | 09:20 AM
KneeDragr's Avatar
KneeDragr
3.Repeat step # 1.
Is there any reason you must be going 60mph? I mean, can you instead go from 35 to 5mph?
Can you tip us to the exact product you used?
Old Aug 8, 2012 | 09:21 AM
mjslouz06's Avatar
mjslouz06
I put Hawk HPS on mine and they do the same. Especially after they have been used a while. If I wash the car the noise goes away, but as the brake dust builds back up the sound comes back. Harder braking eliminates it.
Old Aug 8, 2012 | 09:47 AM
ebf2k's Avatar
ebf2k
Permatex from AutoZone
To Carbotech Brake Problem
