Alignment question
Old Aug 8, 2012 | 12:09 AM
driver71's Avatar
driver71
Default Alignment question
Are the alignment setup specs different for a 2005 with Z51 suspension compared to a non Z51? I did try searching for threads but didnt find any. Excuse my naivety with this as I am in my first year of ownership and am trying to keep on top of any and all maintenance issues with the car.
Cheers
Sorry thought I was posting this under Tech & Perf
Old Aug 8, 2012 | 01:17 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
If there is any difference in alignment specs between the Z51 and base cars, it will be fairly small. And you can use what YOU want anyway.
Many people use the Pfadt Street specs (use the Search feature to get a copy if no one posts them for you), and use the slight amount of toe-IN they recommend also. I use them and am happy.
Those specs are very precise and within the very broad GM specs, so you won't hurt anything.
Just find someone who will set the numbers accurately, not +/- a foot.
Old Aug 8, 2012 | 01:55 PM
Bill Suttie's Avatar
Bill Suttie
All allignment specs. are the same for F55, F51 and base. The only difference is Z06 camber front and rear which is -1.00 degree instead of -0.45 degree. For least tire wear, toe frt&rr should be +0.02 degree with frt camber at -0.2 degree and rear camber at -0.1 degree. Unlike factory specs, there is no +/- values on the above.
Old Aug 8, 2012 | 09:02 PM
Gearhead Jim
St. Jude Donor '13
Agree, but for some reason Pfadt shows toe-In as a "-" number. You definitely want toe-in, not toe out.
The Pfadt camber numbers are more than what you show, but still within the very broad GM specs. I've had good tire wear with negative camber according to Pfadt, but I corner the car hard. A gentle driver might be better off with less negative camber.
Old Aug 8, 2012 | 09:48 PM
driver71's Avatar
driver71
Thanks for the answers folks,,,questions answered as usual!!!
Old Aug 8, 2012 | 10:16 PM
fnsblum's Avatar
fnsblum
I believe the -.45 above is the center of the GM spec and any alignment tech , that knows what he is doing, will set it at that. Mine was -.43-.42 when I put new tires on. 27K later the tires are wearing evenly all the way across. Later! Frank
Old Aug 8, 2012 | 10:26 PM
Bill Suttie
Jim, Thaks for correcting my typo for toe. Toe in is +. Bill S.
Old Aug 8, 2012 | 11:24 PM
Gearhead Jim
St. Jude Donor '13
Actually, I think you said it correctly both times. Toe in is usually shown as +.
But for some reason, Pfadt shows it on their spec sheet as -, although their verbal description mentions it as toe in.
Old Aug 9, 2012 | 12:11 PM
Pfadt Racing's Avatar
Pfadt Racing
We've seen alignment shops signify Toe In as both + and - depending on the alignment machine being used at that particular shop. That's why on our alignment guide we try to be as specific as possible that we want Toe In, not Toe Out.
In case anyone needs a copy of our alignment guide you can check it out here. Click the photo for a full size printable image!
To Alignment question
