Another FOB question?
If you have not programmed a name into the DIC, the DIC should briefly show you the driver number when you start the car. That driver number is actually what fob number the fob that you're using has been programmed into the car.
I have programmed my name and it shows on the DIC, but does that indicate that it is the number 1 fob?
Moderator emeritus
2015 C7 of the Year Finalist
I have the stock key FOB and has not been replaced; The case has a #1 embossed on it.
How many FOBS do you have?
If that's the fob that you were using when you programmed your name into the DIC, it has to be programmed into the car as either #1 or #2. Fobs programmed as #3 or #4 don't have the memory options, which is required to program your name.
OK, thanks, that answers that! Remember the days of just spark, fuel, and air? Those were the days!
