Fuse Sizes??
Old Aug 20, 2012 | 03:28 PM
swglenn's Avatar
swglenn
Default Fuse Sizes??
I purchased a 12V Viair air compressor for my non run flats, as well as tire plugs, and cans of fix a flat for my 2008 MN6 coupe. The air compressor power wire has a male cig. lighter end on it and it needs a 15A circuit. The owner's manual doesn't reference the size of the fuses. I looked in the fuse box and the cigarette lighter and the aux. power fuses are in a separate box that you have to open, BUT, there is a large multi-conductor cable laying on top of the fuse box that looks like it will have to be removed. I DON'T want to do that if I don't have to. Does anyone know what the sizes of these two fuses are?? If I have to I will take a connector that clamps onto the battery and has a female cig. lighter end on it.
