Door opening problem
Old Aug 27, 2012 | 08:13 PM
Jao1968's Avatar
Jao1968
2nd Gear
Default Door opening problem
Any feedback would be great. I have 2009 and the drivers side door will not open from outside or inside. The FOB seems to have a strong battery. All the other components work fine....passenger door, ignition, rear hatch. The drivers door actually tries to engage, the window lowers slightly like the door is going to open but the latch never releases. Any ideas on what it could be? Again thanks for any feedback you can offer!
Old Aug 27, 2012 | 08:15 PM
Olddudesrule's Avatar
Olddudesrule
Use the emergency release to get the door open, and then remove the opening pad and clean the contacts. See if that helps with it opening. Otherwise, I'd say the pad is toast, and you'll need a replacement. not sure how much they are.
Old Aug 27, 2012 | 08:21 PM
johnodrake's Avatar
johnodrake
Moderator
You are likely having a solenoid issue with the lock since both the pad and button are involved. You may still be under warranty, have the dealer check it.
RicK T's Avatar
RicK T
Since you say that
"The drivers door actually tries to engage, the window lowers slightly like the door is going to open but the latch never releases"
I suspect it is the door lock module or the actual latch motor. Need some diagnosing to figure it out. Here are a couple threads that may provide some insight:
http://forums.corvetteforum.com/c6-c...xperience.html
http://forums.corvetteforum.com/c6-c...pen-fixed.html
Old Aug 27, 2012 | 08:54 PM
Jao1968's Avatar
Jao1968
2nd Gear
Man you guys are quick. Thanks for all the feedback. I'll check into all this week and report back.
Old Aug 28, 2012 | 02:31 AM
inner3's Avatar
inner3
Not to sound obvious, but have you charged the battery in the car? also, any electronics in your pocket next to the fob? hope you get it worked out.
To Door opening problem
