Flat bottom steering wheel?
Old Sep 19, 2012 | 10:50 AM
Mew2's Avatar
Mew2
Default Flat bottom steering wheel?
I've noticed the trend of flat bottom steering wheels being put in "Sport" versions of cars and recently the ZL1, but since I've never used one I'm not sure what the purpose is?
They do look very nice but do they serve any purpose? Why doesn't the Corvette have one :[
Old Sep 19, 2012 | 11:08 AM
JSB LS3's Avatar
JSB LS3
I always figured they gave you a little more room for vigorous movement when manipulating the pedals during hard driving.
My Scion tC has one and my C6 doesn't...go figure.
Old Sep 19, 2012 | 11:10 AM
Flame Red's Avatar
Flame Red
Definitely makes it easier to get in and out of the car!
Old Sep 19, 2012 | 11:58 AM
Larry/car's Avatar
Larry/car
Primary, it is the LOOK. I anticipate the C7 as having this feature.
Old Sep 19, 2012 | 12:02 PM
trebor8008's Avatar
trebor8008
I had one in my other car as well and I liked the look and the usefulness. It does make it easier to get in and out. I tend to drive with both hands on the lower corners of the wheel and the flat bottom gave me a great grip.
Old Sep 19, 2012 | 12:05 PM
HammerDown's Avatar
HammerDown
Gives taller drivers more knee clearance when working the pedals of a manual car as well. Especially for heel/toe downshifting, which often requires rotating the right knee under the wheel as the edge/heel of the right foot reaches over from the brake to blip the throttle.
Old Sep 19, 2012 | 12:13 PM
petermj's Avatar
petermj
Flat bottomed wheels, fat bottomed girls?
http://www.youtube.com/watch?v=VMnjF1O4eH0
Old Sep 19, 2012 | 12:14 PM
JSB LS3's Avatar
JSB LS3
The vette wheel definitely precludes me from being able to heel-toe in the normal fashion (mostly a function of my driving position of choice, but still). I'm not overly tall at 6 feet but I prefer my steering wheel to be fairly low. It kind of feels like driving a bus if it's up too high.
I have to use the inside arch of my foot on the brake and tap the throttle with my toe.
Old Sep 19, 2012 | 12:45 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I had the same experience when I moved the wheel to its highest position. But I forced myself to drive it that way for a week, at that point it felt ok and now, months later, I prefer the high position.
Old Sep 19, 2012 | 12:55 PM
BadgeZ28's Avatar
BadgeZ28
I decided to build one and see if it improves getting in and out and how it feels while drivinghttp://i17.photobucket.com/albums/b6...ps3110fafe.jpg
Old Sep 19, 2012 | 02:13 PM
Al Gumby's Avatar
Al Gumby
I've always thought the steering ratio on my `08 is too slow and relaxed for the palm-swell, flat bottom wheels. But I've decided that's one thing I like about my Vette for a road car, its relaxed steering, not cart-darty and nervous. I've had cars that you could corner without taking your hands off the palm swells...great for the track...too nervous for the highway.
As far as heel & toe...there are different ways, and it depends on pedal placement, but I learned from the Stig that my C6 pedals work well with side-stepping. No extra leg clearance needed.
Old Sep 19, 2012 | 02:29 PM
HammerDown's Avatar
HammerDown
Ok, you're going to have to elaborate on this statement. When did you meet The Stig?
Old Sep 19, 2012 | 02:56 PM
JoesC5's Avatar
JoesC5
I was thinking about the flat bottom steering wheel when I went to brunch Sunday. Took the curvy road. I had my steering wheel adjusted so that the top is just above the top of the speedo/tach, to not block my view. That gives me about 1.5" knee room on the bottom. I'm 6'. I don't have a problem using the pedals when shifting/braking.
As for as getting in/out of the car. I have the memory move the seat all the back/down, the steering wheel moves all the way towards the dash, and I manually raise it to the upper position before getting out of the car.
I don't see that a flat bottom steering wheel would benefit me, functionally or visually.
Old Sep 19, 2012 | 02:58 PM
Thrash's Avatar
Thrash
The difference is negligible, there is only like 1/2" or so of space saved, when the wheels are perfectly centered. That could make a difference if you are 400 lbs. but for the most part it is only a styling issue. Personally I'd prefer the flat spot be on top ...
Old Sep 19, 2012 | 03:07 PM
Al Gumby's Avatar
Al Gumby
Ah, never said I met him, and didn't mean to infer so. But I did learn from a camera shot of his foot work while he was driving an Ariel Atom. He side-stepped while braking to blip the throttle and I thought to myself "Self, you just learned something", and it's been working well for me ever since.
Old Sep 19, 2012 | 04:29 PM
cclive's Avatar
cclive
Originally Posted by Thrash
That could make a difference if you are 400 lbs....
So you're saying that the wheel with the flat spot is aimed right at the average Vette driver...
Old Sep 19, 2012 | 04:31 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Replace the steering wheel with a tiller and eliminate the knee-clearance issue entirely.
To Flat bottom steering wheel?
Old Sep 19, 2012 | 06:19 PM
pokerpro's Avatar
pokerpro
2021 C6 of the Year Finalist - Modified
2020 C6 of the Year Finalist - Modified
2015 C6 of Year Finalist
I think its a pretty cool looking mod.
Old Sep 19, 2012 | 06:37 PM
b4i4getit's Avatar
b4i4getit
Maybe the C7 will have a square wheel to be one step ahead of the competition.
Old Sep 19, 2012 | 07:20 PM
JCtx's Avatar
JCtx
THAT looks like crap IMO. If you're going to do a flat-bottom steering wheel, DO IT RIGHT. Which is keep the same diameter, and flatten the bottom, to decrease the distance from top to bottom of the steering wheel. Those abominations use the stock steering wheel, and just elongate the sides below hafway, so they can put the flat bottom. Looks like an afterthought, but to each his own.
This is a proper flat-bottom steering wheel :
But the one I like the best (functionally) is the 2012 Grand Cherokee SRT8's... although the plastic bottom is quite cheesy. I don't like the Ferrari wheel because even all the way down (as shown), is waaaaay too high, and blocks half the gauges. Oh well; nothing is perfect .
