storage question
Old Sep 19, 2012 | 08:46 PM
snowbird12's Avatar
snowbird12
Default storage question
I have a great garage to store my new 08 vert in
Should I remove the battery or not?
I removed the battery in my 03 and had no issues in the spring, but this car has alot more electronic items on it.
Old Sep 19, 2012 | 08:48 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
You can, you'll just need to index windows (turn car on to acc, roll up windows, hold button for 3 seconds in up position, done)
Popular opinion is to use a tender. I use a $19 tender from black&decker that is in every way similar to the Batterytender except in price
Old Sep 19, 2012 | 10:15 PM
CO Lightfoot's Avatar
CO Lightfoot
Instead of removing the battery, just disconnect the negative terminal as suggested on pg 5-49 ("Vehicle Storage") in the online owner's manual:
http://www.gmpartshouse.com/download...09corvette.pdf
Of course, the alarm system will not work with the battery disconnected.
And absolutely make sure your metal key will open the hatch/trunk... to access the pull-tab that manually opens the driver's door, so you can open hood.
Yes, you can leave the hood unlatched. But you'll still want to test the key, in case a well-meaning visitor closes the hood.
I covered the keyhole with painter's tape to keep it from getting jammed with road dust/oil/moisture.
To storage question
