tps sensor question
Old Oct 1, 2012 | 08:58 PM
dlgolder2's Avatar
dlgolder2
Cruising
Default tps sensor question
Does green slime or other types of tire sealant ruin the tps sensors? Are any of you running green slim?
Old Oct 1, 2012 | 10:32 PM
RicK T's Avatar
RicK T
First, from the Owner's Manual:
Notice:
Liquid tire sealants could damage the Tire Pressure Monitor System (TPMS) sensors. Sensor damage caused by using a tire sealant is not covered by your warranty. Do not use liquid tire sealants.
Some say they don't care about the sensors and will use the Slime if they have to. Some just plain don't care. Most follow the advice in the manual and don't use it.
Just a couple prior discussions if you're interested:
http://forums.corvetteforum.com/c6-c...e-sealant.html
http://forums.corvetteforum.com/c6-c...questions.html
Old Oct 1, 2012 | 10:38 PM
cclive's Avatar
cclive
The Slime bottle says it is safe for TPMS sensors because it is water soluble and can be washed off. Here's the link on their web page:
http://www.slime.com/is-slime-tpms-safe-2/
To tps sensor question
