engine tick
Old Oct 7, 2012 | 08:42 AM
onequickvette's Avatar
onequickvette
4th Gear
Default engine tick
I have an engine tick in my ls2 C-6 motor. Auto trans paddle shift.
WHen I start the engine it is pronounced but goes away after a few.
I am thinking one of two things.
First: an exhaust part
Second: sticky valve
THe engine runs a little rocky for 1-2 minutes and then is its same old self.
Any ideas?
Onequickvette!
Old Oct 7, 2012 | 09:18 AM
MelAnn's Avatar
MelAnn
Sounds like a sticking lifter. When was the last oil change?
Old Oct 7, 2012 | 09:28 AM
onequickvette
4th Gear
Default onequickvette
THe oil gets changes every 3K along with the filter. I have not messed with top oils because of Mobil1.
I agree with you that it is a sticking lifter.
WHen using synthetic oils I am always worried about this exact problem.
On all my other vettes I use PenZoil and I have over 100k on one and 60K on the other. Every so often I would add a little Uato transmission fluid to the gas and since it is almost pure detergent my engines are always clean and tidy, no funnty stuff. I drive them hard.
Do you think there is some solution that does not mean replacing the lifter/roller/rocker assembly?
Onequickvette
To engine tick
