engine operation temp
Old Oct 7, 2012 | 03:50 PM
dckotwicki's Avatar
dckotwicki
Default engine operation temp
I have a C6 base and am wondering what the normal engine operating temp should be.
I have been running 190 - 194 deg in warmer temps and am now running 196 - 198 degrees with cooler outside temps. The coolant level is OK and the oil level is OK. This temperature change occured from one day to the next.
It is an 09 with 13K miles.
Any opinions?
Old Oct 7, 2012 | 05:35 PM
RnLi's Avatar
RnLi
You are actually worried about 2-6 degree temperature change? Are you speaking of the exact same conditions. Like fans running and not running.
Was the a/c running at either time?
Was the car in the same type of traffic?
What was the speeds of each?
But frankly, I would be VERY HAPPY if I witnessed that little of a change in engine temperatures and seasons. I don't think you have anything to be concerned about.
Old Oct 7, 2012 | 05:42 PM
Goatdad's Avatar
Goatdad
St. Jude Donor '11-'12-'13
No worries, those are normal temps
Old Oct 7, 2012 | 05:45 PM
VET4LES's Avatar
VET4LES
My average is 196.
Old Oct 7, 2012 | 06:42 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
According to our 2009 Service Manual, the coolant thermostat starts to open at 188'F and is fully open at 206'F. So anything in that range is perfectly normal. In traffic, ours gets up to about 220' sometimes but seldom any higher.
Enjoy your car!
Old Oct 7, 2012 | 06:44 PM
Bob Yocum's Avatar
Bob Yocum
Everything normal,enjoy your ride.
Old Oct 7, 2012 | 06:52 PM
Mad*Max's Avatar
Mad*Max
mine runs anywhere between 200 and 220 - saw some high temps when I was doing a lengthy steep incline on the highway in Wyoming and almost dirtied my pants (that's the problem with too many gauges, more things to worry about)
Old Oct 7, 2012 | 06:57 PM
EVRose's Avatar
EVRose
Tell me about it. I went up 12000 ft at Mt. Charleston and saw my first 220° and almost started to panic.
Old Oct 7, 2012 | 07:51 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Originally Posted by dckotwicki
Any opinions?
yes, you worry too much, come back when it stays above 210 ....
Old Oct 7, 2012 | 07:59 PM
wayback's Avatar
wayback
even 210 is nothing to worry about. Mine sees 220 during the summer here in Tx almost every day.
The fans on the 85 do not come on till 240.....factory settings.
Old Oct 7, 2012 | 08:57 PM
YELW 06 Z51's Avatar
YELW 06 Z51
I average 199. Like everybody says your good to go.
To engine operation temp
