Alignment question
Old Oct 7, 2012 | 09:57 PM
phileaglesfan's Avatar
phileaglesfan
Default Alignment question
What would cause the right side tires to wear out faster than the left. Rt side tires are at the bars, left side have around 4/32. My Vette is an 11GS Vert.
Old Oct 7, 2012 | 10:26 PM
Gary '09 C6's Avatar
Gary '09 C6
aggressive (and uneven ?) toe-in and/or camber settings from the factory, which the GS model is known to receive...
Old Oct 7, 2012 | 11:23 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Is the wear even across the tread on those right side tires, as measured with a tread depth gauge? Or not even?
Old Oct 7, 2012 | 11:36 PM
phileaglesfan
Pretty even, within 1/32
Old Oct 8, 2012 | 03:53 AM
Rossi6998's Avatar
Rossi6998
Just had my tires replaced. My front tires were more worn then the rear tires. The inner portion of my front, driver's side tire was extremely worn.
Had an alignment done because the car was definitely out of alignment...
Old Oct 8, 2012 | 04:52 AM
speedlink's Avatar
speedlink
You have bad alignment!!!!!!
Old Oct 8, 2012 | 06:56 AM
R&L's C6's Avatar
R&L's C6
Can someone tell us if an alignment job for a Corvette is the same as any other car or do you need to find someone who specializes in Corvette's?
Old Oct 8, 2012 | 08:24 AM
9C1's Avatar
9C1
Alignment on C5 & C6 is simpler than most cars, but then you do need to find someone who is in the mode of doing a real alignment. Some "techs" will just "set the toe & go."
A complete alignment on C2 & C3 is a whole other story -- and that is where you need a "Corvette tech." if you can find one who knows those cars.
Old Oct 8, 2012 | 08:51 AM
jrrjbl's Avatar
jrrjbl
With 4600 mils on 11gs cpe, RR outside 2 treads and sidewall at bars. LR close as well. Rest of both rears were +60%.
Dealer who realigned at 600 miles, "oh its GY's fault and the factory agrees". They supposedly set it to the Phat street numbers. By way fronts are +60% and level.
Thank god GY has both class and customer service. They are fixing the dealer's bad alignment and putting two rears on for less than $250 total.
Old Oct 8, 2012 | 09:05 AM
ButWhatDoIKnow's Avatar
ButWhatDoIKnow
Racing counter-clockwise?
Old Oct 8, 2012 | 09:12 AM
wbfiii's Avatar
wbfiii
There seems to be a lot of discussion about tire wear & alignment problems with the GS.
Does the base C6 Corvette have these same problems?
Old Oct 8, 2012 | 10:21 AM
PRicanC6Xpress's Avatar
PRicanC6Xpress
From: From: Brooklyn Kiddo, Live in Wantagh, Long Island NY....... New York
Default Hi
Check your tie rods.......
Old Oct 8, 2012 | 05:57 PM
Gearhead Jim
St. Jude Donor '13
It sounds silly; but is the pavement surface near the shoulder, different from the center of the road?
Old Oct 8, 2012 | 06:44 PM
phileaglesfan
Could be although every single other car I have had/have now don't have the problem.. When they replaced the balancer they had to do an alignment which is off since the car wants to pull right somewhat quick. They'll realign it when I put new tires on it this week. Going with Super Sports for now.
Here is another alignment question. What would happen if the caster on the left front is off (not camber)? Mine is out of spec and the tech doesn't "want" to adjust it because it is a pain. I remember if it was off towards the left of the scale so I think it has more caster than it should.
Old Oct 8, 2012 | 06:53 PM
PatriotZ's Avatar
PatriotZ
Veteran: Marine Corps
From: "No matter where you go... there you are"...."You cannot drive a dollar bill". ...and remember... "D
I too was getting some wear on the inside of my tires....due to the agressive camber/toe in from the factory.....Went to a competent alignment guy....would you believe a Chevy dealer....and he set them way more neutral....since I don't track my car, the setup isn't noticeable...to me... and my tire wear is way more even....
On a side note...because most roads are/have a crown in the center...for rain drainage...that could put a very miniscule wear on the right side....(and that is really pushing it for excessive wear for sure...and remote at that) ......that being said....just do a good alignment.....
Old Oct 8, 2012 | 07:19 PM
judson whitley's Avatar
judson whitley
Had to replace my front tires 2010 GS at 8500 miles i talk tothe Vet tech at Hendricks told him to align the wheels for my type driving i did swith to Mich run flats have 13000 now on new tires hardly any wear d GS is like Zo6 wide much better with this new align
Old Oct 8, 2012 | 07:38 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Remember what OP (Dave) said in his first sentence:
"...the right side tires to wear out faster than the left. ..."
I can think of several reasons, or combinations, but not really any one reason. Most of the answers are about 2 front tires, all tires, etc., but not an answer to your specific question. Bad alignment, other suspension parts that are bad, loose, worn (hard to believe with that little mileage, but anything is possible), even high crown roads (but that isn't your experience w. all other vehicles either). I doubt that it's bad springs, shocks, or worn components but.....
Somehow, I don't see the dealer being able to "diagnose" the issue and then solve it. If it were me, I'd find the best suspension/alignment specialist in town and ask them what they think.
To Alignment question
Old Oct 8, 2012 | 08:49 PM
phileaglesfan
I think the increased caster on one side might cause them to adjust the toe in on the right side causing that side to wear faster. I read that caster doesn't affect tire wear but it will cause it to pull to the side with less caster. Then toe in must increase to make it go straight.
Old Oct 8, 2012 | 10:35 PM
Gearhead Jim
St. Jude Donor '13
Toe usually wears one side of the tire; toe-out wears the insides, toe-in wears the outsides.
There might be some combination of both toe and camber that could cause the problem.
Please keep us posted!
Old Oct 9, 2012 | 09:40 AM
phileaglesfan
I'm going to definitely have them adjust the caster within specs. I think the left was 6.5 which is about 1 degree less than GM specs, right was within specs. I believe they compensated for the caster by toe in on the right so the car will go straight.
