Steering clicks when turned side-to-side
Old Oct 8, 2012 | 07:33 PM
HighPerformanceLS1's Avatar
HighPerformanceLS1
Default Steering clicks when turned side-to-side
Hello All!
I have a 2012 GS coupe with 2K miles. When I turn the wheel from side to side, there's a click/clunk that is heard from what seems under the dash or within the steering column.
It's not just at rest that it does this; I can be moving and mid corner, and when the steering wheel gets pulled the opposite direction I get this click/clunk sound.
I've seen some threads on what seemed to similiar situations, but never a definitive answer on what needs to be repaired or replaced.
Any help is appreciated!
Thank you!
~Lew
Old Oct 8, 2012 | 07:49 PM
MThomas's Avatar
MThomas
There is a batch of bad steering gears in some of the 2012 corvettes. A friend just had to have his replaced and it corrected the issue. Go see your dealer. If they have questions tell them to call the corvette plant.
Good luck.
Old Oct 8, 2012 | 07:56 PM
gjnockie's Avatar
gjnockie
Originally Posted by HighPerformanceLS1
Hello All!
Thank you!
~Lew
It's your steering rack. Mine is on number 2 and it's a 2013.
Old Oct 8, 2012 | 08:17 PM
laconiajack's Avatar
laconiajack
Sounds like a recall should be issued by GM on 2012 and 2013 models with defective steering racks. Hello?
Old Oct 8, 2012 | 10:39 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
We had something similar on our 2009 coupe, dealer replaced front & rear sway bar links and the problem disappeared.
Old Oct 9, 2012 | 06:21 AM
SteveTheRunner's Avatar
SteveTheRunner
7th Gear
And it is a different click then the one coming from the passenger side when the brakes are pressed, right?
Old Oct 9, 2012 | 10:01 AM
HighPerformanceLS1
My sound is different than that, and it only happens when the steering wheel gets moved in the opposite direction, in a side-to-side motion.
To Steering clicks when turned side-to-side
