When to replace TPMS
Old Oct 13, 2012 | 03:49 PM
LS WON's Avatar
LS WON
Originally Posted by tim414
Their designed to last 10 years. So some will last 10+ years, while others will begin to die in 7-8 years.
The ones on my 2004 Yukon started dying at 7 years. (one)......then months later a second. So when I had new tires put on they repld all of them.
They used aftermarket sensors. Two of them lasted 8 MONTHS or less. So, finally Discount Tire ordered GM sensors and I've not had any more issues.
So, figure 7-8 years likely life span of most.
So what happens if you don't replace them immediately? You just don't have a functioning air pressure on DIC? Or can something else become of this if not fixed immediately? Can it wait till you need your next set of tires?
Old Oct 13, 2012 | 04:30 PM
RobVette's Avatar
RobVette
I need to replaced my right front sensor. Can someone recommend a good vendor?
Old Oct 14, 2012 | 04:35 AM
RobVette's Avatar
RobVette
ttt
Old Oct 14, 2012 | 06:48 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Originally Posted by gordonb50
If you want to spend the money, go for it, but they should last a lot longer than that. The only thing I can think of that could damage them sooner is using something like fix-a-flat. The stores will probably try and get you to buy them or even try to sell you the TPMS rebuild kits, but I always pass. Between my C5 that I've replaced the tires 3 times, and my C6 that I've replaced the tires twice, never a problem with TPMS.
Fix A Flat is TPMS safe .................... So is the sealant from Slime. Next time you're in wally world or Auto Zone, pick up a can and read the label.
Old Oct 14, 2012 | 07:27 AM
heli-vette's Avatar
heli-vette
Those sensors are the devils invention . I have had 2 or 3 warnings in 6 months " slow to under 55 mph low tire pressure " . I normally do a soft steering wiggle L / R to feel for a flat corner , pull over to check the wheel .
NEVER WAS IT CORRECT ,
I ignored it for a few days . When I cycled through the display on tire pressure the right rear was zero pressure for days and the warnings stopped . After 4 days its back on line ...working great for the last month
. I'm not worried if I have a flat , it's not a ford explorer roll over crash danger . Its in the same Box as check engine light warnings .
Old Oct 14, 2012 | 07:29 AM
Don-Vette's Avatar
Don-Vette
When to replace them? when they go bad.
If it ain't broke, don't fix it.
Old Oct 14, 2012 | 09:37 AM
tim414's Avatar
tim414
St. Jude Donor '12
On Corvette it's NOT the same reaction you get from other cars (such as my Yukon). If your on a track and a sensor is dead, several things can happen.
1) it will put the car in 'limb' mode when going into corners-which can be dangerous because the car will do it whether you want it to or not;
2) some Z06 owners report cannot turn off nannies such as AH/TC.
BEZ06 is the expert in this area.
Old Oct 14, 2012 | 12:14 PM
Vette5.5's Avatar
Vette5.5
"tims" pretty much got it, and when a sensor goes bad, I'd get it fixed right away. The system is pretty nice to have, as trashed a nearly new rear tire on my daily car a few years ago, not equipped with TPMS. Throw in the added cost of replacing only one tire, and isn't cheap. Know there was somehow mention of fix-a-flat, but wouldn't know. No way any of that goop, is ever going into any of my tires.
Old Oct 14, 2012 | 04:06 PM
LS WON's Avatar
LS WON
got one I think the label says,"4 minutes to inflate 7 to repair" or it's the other way around. This is the fatest one for tire repairs that I could find with Slime co.
But on these larger Corvette tires I am sure it will take longer.
Old Oct 14, 2012 | 04:08 PM
LS WON's Avatar
LS WON
Nothing like the old fashion way of checking tires with an accurate tire guage.
"If it ain't broke don't fix it"
Old Oct 14, 2012 | 04:26 PM
HOXXOH's Avatar
HOXXOH
Originally Posted by Top_Fuel
Since I've had an OEM sensor go bad after 3 years, I'm taking a different approach. When I get new tires and my sensors are 4+ years old, I'm going to buy new sensors.
I have purchased good aftermarket TPMS sensors (Orange Electronic brand) on Amazon.com for about $30 each...so that's roughly $120 for a set. When you have your new tires installed, the shop should "rebuild" your existing TPMS sensors (which basically means they install a new rubber grommet and replace the installation nut). This service costs $5-$10 per wheel and is considered to be good preventative maintenance.
So I figure it's at least $20 to rebuild your existing sensors...or $120 to go with new aftermarket sensors. That means the new sensors really are costing you $100 more than you will already spending to reuse your existing sensors. That's not a huge expense when you are dropping $1,000 on a set of tires. And there's a reasonable chance of selling your used sensors for at least $50 because someone is always looking for a cheap set of OEM sensors.
Hey...there's nothing wrong with rolling for 10 years on the same sensors if they last. But the cost of installing new ones isn't that great if you approach it the right way. Just a thought...
And the Orange Electronics sensors can be cloned to your OEM sensors, so that you can have two or more sets of wheels to swap on and off without needing a reset tool.
Old Oct 14, 2012 | 05:40 PM
Vette5.5's Avatar
Vette5.5
I've heard of the possibility of some sensors being cloned, but curious of how this is done, as the car is programmed to the sensors, not the other way around. I have a Bartec tool, and really think this is the best way. Have track tires for my Vette, and just got a winter set for my daily car from the Tire Rack, with sensors included. Only takes a minute to program them in. Plus, need to program, when doing a tire rotation on my daily cars. All newer cars 08' up, are TPMS now.
Old Oct 14, 2012 | 06:13 PM
  #33
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Yep ............. I carry a can in each car. Never had an issue with the stuff. It is an old wife's tale about it messing up the TPMS
Old Oct 14, 2012 | 06:27 PM
  #34
LS WON's Avatar
LS WON
Along with that I now have air compressor- battery jumper unit, Dyna Plug
Old Oct 14, 2012 | 07:26 PM
  #35
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Yup, every thing fits neatly in the cubbies. Don't know how much night driving you do but I also carry a light weight mesh reflective vest.
Old Oct 14, 2012 | 08:28 PM
  #36
LS WON's Avatar
LS WON
Not really. I would like to buy a larger car.
Old Oct 14, 2012 | 08:59 PM
  #37
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Once Cadillac gets a years worth of production under it's belt with the new ATS, I'm buying one for the s/o and to use as a trip car in rotation with the Vette.
Old Oct 14, 2012 | 09:35 PM
  #38
Mad*Max's Avatar
Mad*Max
Originally Posted by C6Whatever
How many of you replace them when you get new tires? I have an 08 with 15589 miles and just about to need tires. Thanks guys!
Lisa
my 07 still has the original ones and going onto the third set of tires
