disengaging the paddle shift
Old Oct 19, 2012 | 01:17 PM
CorvetteGerard's Avatar
CorvetteGerard
Default disengaging the paddle shift
Hey Guys, is there a way to go back to regular shifting? I've been waiting until the car is at a low speed and switching from neutral back to drive but that can't be safe on the transmission.
Right now i'm under the impression that once you click the paddle (which i accidentally do sometimes) its stuck in that mode until you turn the car off? is that wrong?
Old Oct 19, 2012 | 01:31 PM
MTsVette's Avatar
MTsVette
From: O'Fallon Illinois - Currently own a 2016 Z06 1LZ A8 Coupe
When I'm in Sport Mode (paddle shift) and want to return to "D", I just shift back into "D". I've done it at various speeds with no problems.
MT
Old Oct 19, 2012 | 01:34 PM
Carsonvette's Avatar
Carsonvette
Hold the paddle down for a couple of seconds and it will also return to auto.
Old Oct 19, 2012 | 01:35 PM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
You can put it back in D at anytime, newer models you can hold + and it will go back to auto mode
Old Oct 19, 2012 | 01:39 PM
Vette_DD's Avatar
Vette_DD
No, you can shift to "D" at any speed and it will cancel the paddle shifting.
MT
Only works for model year 010 and newer.
http://forums.corvetteforum.com/1572068640-post2.html
Old Oct 19, 2012 | 01:46 PM
Don-Vette's Avatar
Don-Vette
With the 2010 GS you can only use the paddles in S mode. Which I like, to stop accidentally hitting the paddle. Just hold paddle down for a couple seconds and your back in auto mode.
That said, when I'm at a long stop light I always shift to neutral and take foot off brake if on level road. To keep transmission from heating up and to make my brake light bulbs last longer.
Old Oct 19, 2012 | 02:32 PM
Vette_DD's Avatar
Vette_DD
What do you do when you are sitting a traffic light that way and you see an out of control car headed toward you?
Bulbs and trannies are cheaper than lives.
Old Oct 19, 2012 | 02:59 PM
tlr3715's Avatar
tlr3715
For 2006 - 2009: Move selector lever to "D" to disengage paddle shifting.
For 2010+: Move selector lever to "D" OR Hold the up shift button for two seconds. If you are already in Drive wait 10 seconds without touching the paddle shifter and it will switch back to full auto on its own.
Old Oct 19, 2012 | 03:45 PM
Don-Vette's Avatar
Don-Vette
Lmao!!!
Old Oct 19, 2012 | 03:53 PM
plmkrzy's Avatar
plmkrzy
Old Oct 19, 2012 | 06:10 PM
HOXXOH's Avatar
HOXXOH
The stock converter pumps fluid to the cooler in the radiator at a rate that relates to the engine speed. You get far more thermal fluctuations in engine temperature at a stoplight that affect the radiator and therefore the transmission cooling ability, than the difference of the load on the converter between a neutral position and attempting to turn a gearset.
Incandescent bulb life is mostly affected by the thermal shock everytime they're turned on, not the length of time they stay on. My 102K mile DD still has original bulbs.
You can help the pad and rotor life by creeping forward several inches in 10-15 second time intervals after a particularly hard stop. That allows the rotor to cool more evenly to reduce or eliminate thermal induced cracking.
Old Oct 19, 2012 | 06:46 PM
DigitalWidgets's Avatar
DigitalWidgets
I switched over to run-flat bulbs....just to make sure I can get home in case one fails!
Old Oct 19, 2012 | 06:48 PM
lastcowboy's Avatar
lastcowboy
Hold the paddle down for a couple of seconds and it will also return to auto. or just put it in drive
Old Oct 19, 2012 | 06:55 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Wow, thanks, just like the 10 people before you said. Do people not look to see if the answer has been posted ad nausea already?
Old Oct 19, 2012 | 06:59 PM
kmthor00's Avatar
kmthor00
Correct!
Old Oct 19, 2012 | 07:11 PM
phileaglesfan's Avatar
phileaglesfan
Most accurate answer. With 2011 and up you can also shift with the paddles in drive and it will automatically go back into full auto mode within a few seconds.
You should never have to put it in N to get it back in full auto.
Old Oct 19, 2012 | 07:28 PM
Don-Vette's Avatar
Don-Vette
Thanks for the info.
Old Oct 20, 2012 | 08:47 AM
lastcowboy's Avatar
lastcowboy
Originally Posted by racer
wow, thanks, just like the 10 people before you said. Do people not look to see if the answer has been posted ad nausea already?
i thought you were dead ? YOU MUST BE TIRED POSTING THIS ON EVERYONES REPLY, WA-B
LOL '''..................AND THERE WERE 12 NOT 10 .......LOL
To disengaging the paddle shift
