Battery draining!!
What the hell is draining this system? This system is deader than disco! Not even a click. Battery has been tested, charging system tested. Nothing left on.
Car is at dealer.....I just don't have a lot of faith in these guys.
Any thoughts out there??
That is, the battery might be OK, but the battery-to-starter connection might be damaged/corroded.
http://forums.corvetteforum.com/1581555455-post4.html
http://forums.corvetteforum.com/c6-c...d-battery.html
http://forums.corvetteforum.com/c6-c...ing-issue.html
Or maybe the special cone-shaped terminal nuts are lost:
http://forums.corvetteforum.com/1581748117-post3.html
Anyway, since your battery has died at least twice, you probably need a new one -- especially if it's the original battery.
And if your C6 sits for 2 weeks and/or you only drive short distances, you're killing the battery. Use a good battery tender to keep the battery charged.
But maybe there's something else killing your battery. A seat heater short-circuit or other under-seat wiring crimp/short is not uncommon.
More than you'll ever want to know about battery issues:
http://forums.corvetteforum.com/c6-c...ocked-out.html
Battery died overnight 7.34 volts next day after the car was driven 40 miles plus the day before. ???
I now do not leave home without a jump pack.
Plus now have AAA.
Tech said often, after market components can cause these quirky electrical issues.
Hope they got it this time. Just a few more weeks of good weather before it goes to storage.
