From: US-ARMY 1974-1996 Retired ; Oklahoma, City ; Atlanta, Ga: Hephzibah, Ga
Wheel Alignment
Taking my 05 in for a whell alignment tomorrow. The enter front tires are balding. Call a local shop and they gave me a price of $155. Never had this done before is the price reasonable.
That's a little high but it depends more on your area labor rate and if it's 4 wheel or two wheel alignment.
I am assuming the you meant the center of the tire was wearing, if so, that is a tire pressure problem - too much pressure
Thanks for that chart good information. I meant to say the tires are wearing on the inside on both of the front tires. The chart indicate I need to get an alignment.
I run the street alignment with excellent handling and even tire wear.
The important spec is the Toe, get close to zero has the tech can.
I too run the Pfadt street alignment with just a little toe-IN, car handles great and tire wear seems pretty good.
Negative camber, normal in a 'vette, can wear the inner edges of the tires somewhat. But toe-OUT will absolutely destroy the inner edges and also make the car feel very unstable and twitchy.
