C6 with error P0449
Old Oct 30, 2012 | 02:32 PM
johncalomiris's Avatar
johncalomiris
Default C6 with error P0449
Corvette 2008 c6 getting engine light on , P0449, please help, thanks
Old Oct 30, 2012 | 02:54 PM
tonysrep's Avatar
tonysrep
evap code ,usually you start with checking the gas cap ,some gas stations don't tighten it as tight as it need to be , if its tight ,I'd start with replacing the cap first before the evap solenoid
Old Oct 30, 2012 | 05:43 PM
johncalomiris
We just changed the gas cap, the light is still on. Can you send me a link on the evap solinoid for a 2008, thanks
Old Oct 30, 2012 | 06:25 PM
speedlink's Avatar
speedlink
You need to have a number of start stop cycles before the light goes out.
Old Oct 30, 2012 | 06:34 PM
crusher1's Avatar
crusher1
Either that or get a scanner and erase the code
Old Oct 30, 2012 | 09:44 PM
JKbride's Avatar
JKbride
W. GA Events Coordinator
St. Jude Donor '12-'13-'14-'15
Check out this thread.....it will help you.
http://forums.corvetteforum.com/c6-c...49-w-pics.html
To C6 with error P0449
