I got gas
Old Nov 1, 2012 | 04:35 PM
mg777's Avatar
mg777
Default I got gas
First week of Vette ownership is progressing smoothly. I am thoroughly enjoying motoring around town with my "S" mode on. Now, almost time for her first fill-up.
According to my directions, my engine on this 2013 Coupe can take 91 , but I've always heard to use 93. What grade of gas do you put in your corvette ? Also, do you have preferred gas stations where you think one brand's gas is better for the engine than another's? The manual says to visit toptiergas.com, and those stations have the best. Any validity to this?
Old Nov 1, 2012 | 04:36 PM
saplumr's Avatar
saplumr
The ones that can get 93 use it. I think some states only have 91.
Old Nov 1, 2012 | 04:53 PM
Kvothe's Avatar
Kvothe
I always use Shell 93.
Here's a link to top tier gas suppliers:
http://www.toptiergas.com/retailers.html
Old Nov 1, 2012 | 04:55 PM
myfunz's Avatar
myfunz
Top tier all the way. I use 93 when I can get it. Big performance change with the octane! She wants to fly.
Old Nov 1, 2012 | 05:07 PM
dvilin's Avatar
dvilin
Sunoco 93 octane always.
Old Nov 1, 2012 | 05:16 PM
brooklync5's Avatar
brooklync5
93 for me only problem now especially here in NY in thr five boroughs is that every single gas station is OUT of fuel all grades.... thanks sandy
Old Nov 1, 2012 | 05:24 PM
RO55's Avatar
RO55
Old Nov 1, 2012 | 06:10 PM
su8pack1's Avatar
su8pack1
93 here.
Old Nov 1, 2012 | 06:13 PM
Don-Vette's Avatar
Don-Vette
93 Mobil here.
Old Nov 1, 2012 | 06:19 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Don't know where you are at since your profile says nothing, but if you're in CA 91 is all you can get. I use octane booster when filling with 91.
Old Nov 1, 2012 | 06:20 PM
EVRose's Avatar
EVRose
I only use 91 since that's as high as it goes around here. According to the manual you can run fine on 87 but the higher is preferred.
Old Nov 1, 2012 | 06:25 PM
WICKEDFRC's Avatar
WICKEDFRC
87 Octane here and zero issues for many miles of smiles.....
Ok, just kidding. My ride is tuned by Team LG for 91 Octane. Zero issues.
Old Nov 1, 2012 | 06:49 PM
speedlink's Avatar
speedlink
91 is what the manual says. 93 is fine, but overkill.
mg777's Avatar
mg777
. We have 93 and 91 here in FL
Manual says 'if the vehicle has 6.2L V8 (VIN CODE W) , use premium unleaded 91 or higher. You can also use regular unleaded rated at 87 or higher, but acceleration could be slightly reduced , and slightly audible knocking noise might be heard.'.
Manual suggests 93 for best performance if vehicle has 6.2 L V8 (VIN Code T ) or 7l V8 (VIN CODE E), I'm guessing that means the manual and Z06, ZR1
Now, no way I'm putting 87 in my Vette, but Will I be able to tell a difference in performance between 91 and 93 in my automatic coupe? I can't remember off the top of my head the difference in price here between the two, but I'm going to check it out and will report back
Old Nov 1, 2012 | 07:12 PM
SHM's Avatar
SHM
I'm using as per recommendation of the owner manual. Min. 91 octane. Though the last batch of fuel wasn't top tier...Oh well, some BG44K or Chevron Techron will take care of that when I get the oil changed...But, mostly, I fill up on top tier...Mobil, Exxon, Shell...which are the top tiers available in my area....
Old Nov 1, 2012 | 07:19 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
My choices are 87, 89 or 93. We burn 93 in 2 of the vettes and 2 of the bikes...
Old Nov 1, 2012 | 07:32 PM
Kwagnerhvac's Avatar
Kwagnerhvac
I've run 89, 91, and 93 each many times. I don't notice one bit of difference between the three except the price per gallon. I don't seem to get any better gas mileage or performance between 89 and 93. No pinging or any negative side effects from 89. Many will say you can't run 89 but I sure don't agree.
To I got gas
Old Nov 1, 2012 | 07:35 PM
Supersonic 427's Avatar
Supersonic 427
I run Shell 93.
Old Nov 1, 2012 | 08:04 PM
SHM's Avatar
SHM
I think if one owns a LS7 or LS9 engine, imo, 91 is as low as you'd want to go unless it's a dire emergency.
Old Nov 1, 2012 | 08:09 PM
lordofwar's Avatar
lordofwar
always use the highest octane you can get.the cost difference is peanuts between 87 and 93.why not use the best.
