Which Octane for Corvettes
Here is one of many articles:
http://www.consumerenergycenter.org/...s_premium.html
I personally use Premium, but at what extra cost if it has no benefit?
http://forums.corvetteforum.com/c6-c...i-got-gas.html
"Most modern cars, however, are designed to employ a specific compression ratio, a measure of how much room is available to the fuel when the piston is at the bottom and the top of the cylinder. This compression ratio—somewhere in the neighborhood of eight to one—tolerates lower octane fuels (such as regular gasoline, good old 87 octane) without knocking. "The compression ratio is fixed by the designer of the engine," Green says. "The regular fuel will burn properly and the premium fuel will burn properly and therefore there is no reason you should pay the extra money." High-performance engines, such as those in some sports cars or older, heavier automobiles, often boast much higher compression ratios. These cars—for example, Shepherd's Subaru WRX—require premium gasoline and will definitely knock without it."
I paid over $30,000 for my 05 (I bought it used) and I've been saving so much $$ by using 87 I will be able to but a C7 as soon as they come out.... I'm looking to see if I can find 87 or 85 octane and save another .03 cents a gallon...
OH BTW I also saved enough to send my car to Cartek for a "Supercharger" and I still run it on 87 ...
Do you think I can get by with Walmart brand oil instead of wasting $$ on Mobil 1 synthetic??
Please give me as many hints as possible to save $$... I already go to the FREE car wash at the local gas station if I fill it up....
The kid put a little curb rash when he misjudged the curb after he drove it through the car wash... But I didn't mind as I had saved Sooooooooo much $$ by getting PI$$ A$$ 87 gas....
Looking forward to some money saving tips...
It's not about saving money. It's maybe another scheme for the gas companies to make more billions of dollars from the consumer.
There are alot of studies out there, is all I'm saying.
The Department of the environment would frown on that
