OEM replacement interior part help
Old Nov 5, 2012 | 10:34 AM
Kseiter's Avatar
Kseiter
Default OEM replacement interior part help
I recently had a custom stereo installed in my 2013 427 vert. The shop installed 2 8w6's behind the head rests in two separate custom enclosures which required some cutting of the divider which separates the interior and trunk. It sounded like total crap so I had them install a 12" sub in the trunk.
The divider was more or less destroyed in the process and I'm looking for a replacement. For the life of me I cant seem to find one! Can someone please help point me in the right direction... What the heck is the part called and where can I get one? I don't want to go to the dealer if at all possible.
Thanks in advance!
Old Nov 5, 2012 | 10:49 AM
96GS#007's Avatar
96GS#007
A picture usually helps
Old Nov 5, 2012 | 10:59 AM
Kseiter's Avatar
Kseiter
If I had the original I would post a pic, but they disposed of it before I could get any information off of it or before I could snap a pic.
I recall that it has weather stripping across the top. It also had the original real speakers mounted to it. I'm sire its a common part, I just need the part number so I can order a replacement.
Thanks!!
Old Nov 5, 2012 | 11:21 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
I think what you are looking for is called the Partition Panel. This is the part that is in the center of the seats between the convertible top and the cargo area (trunk).
If so, it is GM part number 15216916.
If not, could you describe a little more of what you are looking for because other than that, I'm not sure.
***Never mind. I just went look again. You are looking for the Closure panel. The note about the speakers mounted to gave me a better idea.
It is GM part 15221958.
Old Nov 5, 2012 | 12:26 PM
Kseiter's Avatar
Kseiter
It is GM part 19221958.
Thanks - Let me take a look and see if this is it.
Old Nov 5, 2012 | 12:32 PM
Kseiter's Avatar
Kseiter
Nope thats not it. Thats the part the the top sits in when it's down. I need the part that is verticle and houses the original OEM rear speakers
Old Nov 5, 2012 | 01:11 PM
talon90's Avatar
talon90
NCM Ambassador
Are you telling me that 15221958 isn't it?
Part #1 As viewed here:
http://store.gmpartshouse.com/parts/...agramCallOut=1
This is the part that holds the rear speakers. The round opening just behind part #4 is where the speaker sits.
I had typed the part number incorrectly above. Should have been 1522, not 1922.
Old Nov 5, 2012 | 01:52 PM
Kseiter's Avatar
Kseiter
Thats it... you found it. No wonder I couldnt find it - all the OEM reseller have it in the quarter panel section.
Thanks alot for the help!
Old Nov 5, 2012 | 02:29 PM
Kseiter's Avatar
Kseiter
Looks like the part number is 15942817
Old Nov 5, 2012 | 02:36 PM
talon90's Avatar
talon90
NCM Ambassador
Yep, that's correct. That is the current part number.
Old Nov 5, 2012 | 06:51 PM
RedRider1's Avatar
RedRider1
They might have it here. http://www.corvetterecycling.com/
To OEM replacement interior part help
