heated seat problem
Old Nov 8, 2012 | 03:02 PM
Prodago's Avatar
Prodago
Default heated seat problem
Hey guys/gals,
Just had seats redone with yellow inserts, came out looking great. will try to post some pics, however my heated seat doesn't work anymore. the passengers works, but drivers is out. Someone said that when they recover that they do not take the oem heater out of the old cover and put it in the new, however it just occured to me that if this were true then neither seat would work.....
I will start with changing the switches out, but after that...I'm at a loss.
Help please
thanks
John
Old Nov 8, 2012 | 03:17 PM
96GS#007's Avatar
96GS#007
Originally Posted by Prodago
Hey guys/gals,
Help please
thanks
John
I'd start simple and look under the seat to ensure all the seat connectors are plugged in/fully seated. Wouldn't be the first time a connector wasn't quite seated or popped loose or was overlooked during install.
Old Nov 8, 2012 | 03:27 PM
VET4LES's Avatar
VET4LES
Make sure all of these connectors are tight. I zip tied them so they will not pull apart.
Old Nov 8, 2012 | 03:32 PM
johnodrake's Avatar
johnodrake
Moderator
There are two connectors for the seat heaters, one for the back and one for the seat bottom. They are up under the back of the seat cover material.
Old Nov 8, 2012 | 03:51 PM
Prodago's Avatar
Prodago
and in order to get to them I will have to take the cover off??
also good tip about the zip ties, hadn't thought of that
To heated seat problem
