Grumbling
Old Nov 9, 2012 | 03:59 PM
hondaamer's Avatar
hondaamer
Default Grumbling
I've got a bad grumbling noise coming from under the car. I put it on the lift and it's coming from the torque tube. Brought it to the dealer and just waiting for the news. 2010 coupe 17k miles shouldn't have a problem like this imho.
Mike
Old Nov 9, 2012 | 05:03 PM
Landru's Avatar
Landru
Crap breaks, thankfully your warranty will cover costs. Let us know WTH went wrong.
Old Nov 9, 2012 | 06:21 PM
MR_JLR's Avatar
MR_JLR
does it make the noise at all times or only when cold or hot?
Old Nov 9, 2012 | 06:44 PM
Goatdad's Avatar
Goatdad
St. Jude Donor '11-'12-'13
Old Nov 9, 2012 | 09:40 PM
cclive's Avatar
cclive
Sounds like a bearing inside the torque tube, especially if it stops when the clutch is pushed in. Unlike most cars, the driveshaft in the Corvette spins when the car is in neutral.
Old Nov 10, 2012 | 09:24 AM
choprfgr's Avatar
choprfgr
You may have run over a troll.
Old Nov 10, 2012 | 09:26 AM
boraxman's Avatar
boraxman
Good luck on the repair
Old Nov 10, 2012 | 12:50 PM
grayline's Avatar
grayline
Easy fix small monkey in there banging with a wrench.
Just take away the wrench..........
Old Nov 12, 2012 | 01:16 PM
hondaamer's Avatar
hondaamer
Mike
They say it is the bearing, good call cclive. Can't find the monkey, grayline, thanks anyway
Old Nov 12, 2012 | 03:38 PM
Bill Dearborn's Avatar
Bill Dearborn
That is the way a front engine rear transmission car works. No way around it. If you put the clutch in the rear the drive shaft would be turning all the time instead of just when the clutch is engaged.
Bill
Old Nov 12, 2012 | 07:12 PM
cclive's Avatar
cclive
Bill
I just mentioned it because the bearing would stop making noise if the clutch was pushed in...I figured it might help him diagnose.
Old Nov 12, 2012 | 10:42 PM
mundo's Avatar
mundo
The Flux Capacitor is making noise. Check to see if its getting 21 Gigawatts of power?
To Grumbling
