Help please
Old Nov 11, 2012 | 12:15 AM
deejaydu's Avatar
deejaydu
Default Help please
I own a 2007 convertible that I bought new. The power top has always worked perfectly until this week. It will go all the way down but instead of closing the decklid completely just before the chime is supposed to sound the decklid raises slightly and the the chime never sounds. And of course the decklid is not completely closed. It goes up just fine without any problems. Has anyone else ever experienced this. If so can you tell me what I need to look for to fix it.
By the way the top never binds or hits anything. It has never been to the dealer or anyone else for any adjustments. I hope that it is something simple.
Thanks in advance.
Old Nov 11, 2012 | 07:48 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Check the micro -switches on the passenger side. Mis-alignment of the switch will cause this.
Old Nov 11, 2012 | 08:04 AM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
This is one item I don't recommend trying yourself. It may very well be a simple adjustment but if you do it wrong it could be serious money in broken equipment.
Take it to the stealership.
Old Nov 11, 2012 | 09:17 AM
TexasMadMan's Avatar
TexasMadMan
I went down the same road a couple of years ago. Sounds like a switch issue to me and that will mean a trip to the dealer.
btw, mine is also an 07.
Old Nov 11, 2012 | 11:23 AM
deejaydu's Avatar
deejaydu
Thanks for the comments . I was afraid it might have to go to the dealer. That is unfortunate. I will just look the switches over to see if I see something obvious. Where exactly are the switches located.
Old Nov 12, 2012 | 09:43 AM
deejaydu's Avatar
deejaydu
Does anybody have a picture of the switch locations.
To Help please
